bar end mirrors
mikeadamstattoo
Coast to Coast
am i doing something wrong? i cant get the telescoping nuts that spread out in the bar to..well, work. it just spins inside the handlebar and doesnt do a thing as much as i turn the allen key. am i doing something wrong?
got a pic?
Did you get the right size? At least the bar end mirrors I've seen have two different sizes 14 and 18mm(I think). the first being for steel 22mm bars and the second for aluminium bars ( with a thicker wall). If you've checked this and it's still spinning (not catching on) try to expand it a bit before putting them on , just so you can get it snuggly into the bar end, and then tighten from there. I'd also check that there's no grease/oil in the bars.
Ya mike, they can be a pain. Tighten them as much as you can and still get them into the ends of the bars. Than start tightening some more.
Get some expansion bolts from Home Depot, they work much better and you won't have mirrors flopping around in a few months
PJ
they're a stupid design. as soon as they grab you're golden, but getting them to? i've 're-engineered' them in the past by drilling a tiny hole in the face of the nut and putting a little bit of safety wire in the hole and then pushing the protruding wire into the rubber plug. that stops the nut from spinning just enough to get the rubber to bite inside the bar and then friction takes over. i've also thought that maybe if you glued the nut on with say some silicone, if that would hold it long enough to get it started... let me know how you get on if you try that method!!!
Mike, did you get this resolved? If you are having a hard time tightening it, try to pull the spreader bracket out and make sure there isn't a gouge on the surface that the nut's catching on.
If there is nothing for the nut to hang up on, put the bracket in with the nut still loose. Then take just the bolt (no mirror) and thread it into the nut. Get some pliers or something and push the bracket into the bar while gently pulling the bolt towards you. That should "set" the nut well enough to unscrew the bolt and put the mirror on
