Mike, did you get this resolved? If you are having a hard time tightening it, try to pull the spreader bracket out and make sure there isn't a gouge on the surface that the nut's catching on.
If there is nothing for the nut to hang up on, put the bracket in with the nut still loose. Then take just the bolt (no mirror) and thread it into the nut. Get some pliers or something and push the bracket into the bar while gently pulling the bolt towards you. That should "set" the nut well enough to unscrew the bolt and put the mirror on
