Bearing boring?
QuackAttack
So here is the deal i have a 20mm front axle bolt. The wheel i am planning on putting on it has a slightly smaller bearing on it. We are talking like .006". if i was to bore that out using a dremel or something similar would that work and be okay? Any help would be great.
The set up is a 93 GSXR 750 front end and the wheel is a harley narrow glide.
No. Just no...nonononononono :o
Just get the right bearings for your axle, do it right and safe the first time. You have to keep in mind that this wheel is responsible for keeping you upright and rolling, while it may work, I wouldnt personally put my physical health in the hands of a jury rigged set of bearings!
Contact the folks at https://www.allballsracing.com/ or hit up their size chart here: http://www.allballsracing.com/media/productshowcase/AllBallsBallbearingsizechart.pdf and find the correct bearing size(s) for your application.
As long as you know you sizes; width, OD, ID. It's not that hard to find the right bearing number and not be sloppy.
xb33bsa said:
you could probably get it to work using flamabull chemicals and then setting it on fire
That's the best bad spelling of flammable I have ever seen....
Now, is it flammable or inflammable??? LOL
xb33bsa said:
try saying that fast with yer teeth out
might need to wait a few years. I don't have removable teeth (yet ) :)
Sent from planet Earth using mysterious electronic devices and Tapatalk
