YogiBear
Over 1,000 Posts
The one in question is on the CR750 styled 750. Its the same bike just painted in the later pics. I checked airtech with no luck.
YogiBear said:are you thinking RICCR1S? The cutout looks alot different between the two
o1marc said:Cut outs are usually modified to fit the application, some are bigger than others depending on clip-on/handlebar location. I have a full fairing from AirTech that I had to mount with the clip-on tucked all the way in just to have clearance to get it on the bike. Then trim for control clearance.
You'll notice on the blue Honda the clutch lever barely clears the fairing, it was trimmed from the original piece in the AirTech photo.
hillsy said:You're right about cutting out the scallops to suit the application, but I don't think this one is the Air-Tech Rickman. The front of the Rickman is "flattened" compared to the round profile of this fairing. I'd say Ducati copy or maybe Dunstall copy (??)
o1marc said:Airtech carries about 10 different variations of that fairing for the Rickman, different Ducati's and other applications. They have them with a flat nose, round nose, or the headlight hole cut out. Their fairings are all molded off one of the OEM fairings.
Check them out here:
http://www.airtech-streamlining.com/vintage/vintagefairingshalf.htm
