Carb boots.
Firestarter
Ok so I cannot find a decent set of VM28 Mikunis for my GT550 for a decent price anywhere. However I did find a set of VM34 carbs off a 600cc two-stroke snowmobile that look like they will do the job nicely. I have a couple issues fitting them however:
First, I need to switch out the throttle cable from my 74 to one for an older 73 model so that the OMp works properly. This is not a big deal, but has to be done.
Next however, I need to mount the carbs. This is an issue. The OEM boots are large enough on the cyl head side of the boot to fit the carbs, but the carb side is not, as it was sized to fit the VM28's. I THINK CB750 carb boots will work, but I am honestly not sure as I no longer ahve a set here to measure. I measure the outer dia of the carbs at 40mm, and the outer dia of the cyl head spigot at between 39 and 40mm. Any ideas?
Any help will be gratly appreciatted!
First up, if your bike wants VM28s, you're going to be VERY disappointed when you slap on some VM34s. Check and made sure that snowmobile is a triple before you make that change. Carbs should be sized on a per-cylinder basis and not simple by the total ccs. My guess is that VM34s might be a bit big as my T500 is running VM36s and the per-cylinder displacement is 250cc.
Second, I can get you some brand new flat-slide VM28s for $110 each ($330 total for your triple). PM me if you're interested.
The snowmobile is a triple, and I think it is actually a 580cc. Obviously a little more modern technology than my piston-port 550, however several people have done VM32's with no issues, dont think anyone has ever tried VM34's as yet. These were practically given to me (50 bucks for the set) and are in good shape, literally taken off a wrecked but running sled. Fortunately there are a lot fo those things around Denver. I am a little concerned about it being overcarb'ed, but we will just have to see. I really think it was undercarbed a little from the factory.
I seriously looked at doing the VM28 slide valves, but tbh that option looks to create even more headaches for me. Obviously the snowmobile jetting is going to be a bit off, but it should not be that far off.
The biggest issue is getting them actually fitted. I have some reinforced silicone hose that could be use, but obviously would not be as stiff as the original boots or "neck down" etc. like the original carb boots. I could maybe carve out the OEM boots a couple mm to fit, but thats going to be a PITA that I would hate to resort to if the solution is as simple as fitting a set of CB750 or similar boots.
The other issue I forgot about is the sled uses a cable choke screwed into each carb, and it was left on the sled. Looks like what it is going to need is a lever style with a crossbar arrangement, again like a CB750. I am going to the motorcycle salvage yard tomorrow to see if they have anything. I really dont want to use a cable choke and have yet more crap running up the bars but that might be the only answer.
I was thinking the same thing. Too big. They might work for the dragstrip with porting and expansion chambers where a very peaky powerband is OK, but I'm thinking for street use, the low end performance would be awful.
Firestarter, you mentioned VM28s in your original post and I'm interested to know where that was mentioned. How or where are VM28s mentioned in relation to your bike?
The VM28SC is the original carb type for the bike as delivered in 1974 by Suzuki. I have about a set and a half of usable carb bodies, but would have to buy pretty much every screw, jet, em tube, choke plunger, etc as the original disassembler of the bike managed to misplace all the small parts to the carbs. I am in constant search for a set of usable ones and have missed a couple of sets on ebay,
Since the OEM carbs for a 74 are plate mounted, I am left with either
a) waiting for a set to come up and buying/rebuilding them
b) sourcing ALL of the small parts for the carb bodies I currently have, many of which parts are NLA, and which will take a lot of time and frustration I really dont have the personality to deal with.
c)fitting a different set of carbs and making them work. I have spent a fair amount of time comparing different triple carb setups and looking to see whats out there. This leads comes the VM34's. Used on a Polaris 580cc two-stroke triple snowmobile, the linkage will work as I can simply backdate my bikes 1974-up throttle cable setup (push-pull) to the 73 and earlier single to triple cable setup, the carbs will fit and even use the same filters etc.
The rub is the carb boots, which I will figure out one way or the other.
IF it ends up way overcarbed I have lost a little time,but not much else, as the VM34's will always be worth more than the $50 I paid for them. IF they work then I solved the biggest issue with the bike, which is the antique and hard to find carbs. IF not then I am no worse off than I am right now, which is I have a bike ready to start with no carbs.
If the top linkage is good, there are people looking for one.
28 is enough to make about 60Hp on an RZ350 twin, (they are actually 26mm but who is counting) and that's the same as a 90HP 525 triple, so it isn't over carbed as such. My 350 TZ race bike has a pair of 34mm carbs and they are fine for 11,000 and >70hp on that motor.
My guess is that 34mm is too large on the street. 30mm if you want to, but 34 is too large IMHO.
Ok so I guess it is always strange how things work. Never could find any info about which carb boots might fit, so I took a little time to stroll around the local cycle salvage this morning. I have asked the guys behind the counter a few times if they had any GT550's or parts, and they basically told me they didnt think they did. Unlike most of my trips over, today I actually had plenty of time and it was not crowded at all. ALLLL the way in the back I find not one, but 5 GT550s, 3 of which had the right carbs with most of the carb bits. I also found another flip-top lid for my tank and a couple other odd little bits.
Went back inside and asked about them, fully expecting to hear $100 a set for the rack mounted carbs. The guy behind the counter- Ben- said $50 bucks for carbs out in the yard, and loaned me some tools to pull them. 30 minutes or less later I am back at the counter with the carbs and bits. He took one look at the rusty pile and charged me $53 bucks out the door.
Now I can sell my very nice VM34's and come out with a running bike after all!
