Firestarter
Ok so I cannot find a decent set of VM28 Mikunis for my GT550 for a decent price anywhere. However I did find a set of VM34 carbs off a 600cc two-stroke snowmobile that look like they will do the job nicely. I have a couple issues fitting them however:
First, I need to switch out the throttle cable from my 74 to one for an older 73 model so that the OMp works properly. This is not a big deal, but has to be done.
Next however, I need to mount the carbs. This is an issue. The OEM boots are large enough on the cyl head side of the boot to fit the carbs, but the carb side is not, as it was sized to fit the VM28's. I THINK CB750 carb boots will work, but I am honestly not sure as I no longer ahve a set here to measure. I measure the outer dia of the carbs at 40mm, and the outer dia of the cyl head spigot at between 39 and 40mm. Any ideas?
Any help will be gratly appreciatted!
