cb 360 tracker project
dries
CB360 after a little week, now facing the electrics and wiring. Any of you guys have advice?
My advice is that you go to this thread :http://www.dotheton.com/forum/index.php?topic=67408.0;topicseen
And enter the September 2015 Ichiban Moto Badass Grinder Sparks contest!!
new slash cut mufflers installed, wiring is getting fixed and installed some "cat eye" indicators
My advise, re-install air boxes/filters, front & rear fenders, original mufflers. Give her a proper tune up and ride.
Ryan Stecken said:
Buy a sparck moto loom and rock on mang.
+1, along w a sprackmoto R/R.
Remove the improperly fitted gators.
Download and read Workshop manual
Clean up & service OR replace.
all brake pads
wheel bearings
stem bearings
forks, fork seals and fresh oil
tires, tubes, strips, spokes, straighten and balance wheels
control switches, throttle sleeve and all cables
swing arm bushings
Replace rear shocks w better than oem, proper for the bike.
chain/sprockets
check compression
adjust cam chain tensioner, valves, engine oil, spark plugs, points, clutch
clean carbs and inspect all internal parts, insulators/gaskets
exhaust leaks
clean tank/tap
repair/replace air filters, rubber parts assoc w filter boxes
electric starter
test charging and ignition system.
Paint it the color of your choice. ;)
Tip...contact DTT member "crazypj" about tuning stock CB360 for filter/exhaust changes.
Heres a few threads about most everything I know...which aint much. So, good luck. Let me know what recipe you come up with.
http://www.dotheton.com/forum/index.php?topic=63133.0
http://www.dotheton.com/forum/index.php?topic=38240.0
http://www.dotheton.com/forum/index.php?topic=60728.0
Nice converted horse barn!!
If no front fender and I think it's entirely up to you if you like shit in yer face, but use the fender bracket to make a brace up... it can turn out cool and will take the deflection/wobble out some ans even knock half of the shit down.
Front and rear fender are going to be installed, probably gonna shorten them in a little. Also considering putting same sized tires on the rims. A friend bought these and they are really looking great.
http://www.tirendo.be/
You need to compare rear shock travel w tire to frame hoop distance. You don't want to get into a situation in which the tire hits the frame.
And consider installing hangers on the mufflers.
Black on the mufflers looks good. 8)
That hoop is definitely going to hit your rear tire when going over a bump, especially with the spongy stock cb360 shocks. I've made the same mistake in the past. What happens when you're going 50 and you hit a bump and your rear wheel smashes into the hoop and comes to an instant stop = not much fun. I also made the same mistake of having a very slim seat with no cushion, your ass / back won't enjoy it after 30 minutes of riding.
These guys know there shit, I highly encourage you to take their advice very seriously! I was once where you are with my first build a cl360, and chose aesthetics over functionality.
Aesthetics should never take away from performance and safety. Did you rejet the carbs for those airfilters? If not you may experience some bogginess accelerating. There is also a thread on here somewhere explaining why cheap emgo air filters actually block air flow into the carbs, and you should really go with some k&ns or higher quality (even though they're more expensive).
Not trying to seem overly critical, just trying to save you some heartache I went through.
Good luck, the 360 is a great bike
Hi guys, thx for the advice.
For the space between my wheel and seat, I did not lower, just shorten it, do you think this is a prob? Will it be the same if I install thougher ones (any of you guys now which would be suitable?)
Cheers
You basically did lower it. By shortening it w that hoop, you have removed about 1.5 inches of travel twixed tire and frame.
You "could" install stiffer shocks. The problem is you are investing time, effort and $ into a bike that will be uncomfortable, unreliable and won't handle as well as it should.
This all adds up to a bike you won't enjoy riding.
A bike you won't ride.
Early on I had purchased a pair of shocks for my 360 from DCC, I didnt consider at the time, they were stiffer. They ended up in the dumpster and now I have custom Hagons built by davequinnmotorcycles.com .
