CB125s build. "The Dishwasher"
Re: CB125s build. questions abound!
Well, minor update:
I got the new floats in, and the carb all back together (I still need the inlet needle, my point cover gasket and dynamo cover gasket, as well as the main carb seal kit) just to test it out.
It revs so much more cleanly! No more bogging unless I dump the throttle open at idle (which is how it should be with a slide carb, I've been told.)
I rode it down the street with my friend, and now it's hesitating a bit when I'm trying to maintain a constant RPM. It does it less at higher revs, and more at lower. I'm guessing, it just needs the gasket between the carb and the intake manifold. That, or when I accidentally ran it out of gas, it sucked up some sludge into the carb. I'll clean it again when I get the new gaskets in sometime this week
I adjusted the ignition timing to be spot on (that one was a damned learning process! Wound up using a volt light. The points were so dirty that when the points touched it wasn't grounding out, lol. And the ignition was a touch retarded.)
The good news is that the compression came back at 160-165 when it's hot (perfect is 170)
Also scored a perfect front fender, rear seat, and exhaust to modify for $25
Now I'm trying to figure out what to do for turn signals and a taillight. Will something that's 12v work on a 6v system, just be somewhat dim?
Looking at this for signals
http://cgi.ebay.com/ebaymotors/4-X-Universal-Amber-Turn-Signal-Lights-Bulb-Motorcycle-/180410318295?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a014afdd7#ht_4216wt_939
And this for taillight
http://cgi.ebay.com/ebaymotors/Motorcycle-LED-Brake-Tail-Light-ATV-HONDA-KTM-Harley-/260760266099?pt=Motorcycles_Parts_Accessories&hash=item3cb685e573#ht_2166wt_1165
I'm still confused about the 6-12v deal. I really don't think I want to go through the troubles of rewinding my bike for 12v...
I don't think they will light up enough to be useful, but could be wrong. I was looking around on mini bike forums before and they had all sorts of links to places that sold 6v bulbs. Might want to try that. My biggest concern would be if ordering a "specialty" bulb and it blows- then have to wait for another to come in.
Wouldn't I have to replace the headlight bulb, as well as the lights in my instrument cluster, then?
Also sucks since I already bought a new 6v battery and a 6v battery charger, lol
Also, could you elaborate on the "black to switched 12v"
I understand the rest, but have no idea what "switched 12v" means.
All I'm really worried about is finding a 12v headlight bulb that will work, figuring out the proper battery to get, and finding 12v bulbs for my gauges.
Also, what shocks did you use on your xl100 build? I'd love some remote resevoir shocks.
And where'd you get the steering damper/rearsets/foot control extensions? I'm probably going to have to make a custom subframe for rearsets, as the frame on my CB is very short.
eeeenteresting. I just discovered the xs650 speedo I have works with my CB!
Speedo spins up, has all the lights required to match the stock CB configuration. It looks silly next to the stock tach (my old tach is ignition pulse, sadly) but when I decide to break down and really have some fun with this project (after performance and stance issues are worked out, I won't have to drop $130 on a new speedo again!
I could, in theory, use the horn's hot lead for ignition switched power, then.
Found the shocks on ebay. Those look kickass. I'll definitely be going that route! the rears on mine are a bit... Bouncy. Need to rebuild my forks, too. They hiss pretty hilariously when compressed.
So all I'm going to need is a 12v battery (what battery did you run on the XL?) and that regulator/rectifier? And obviously switching out all my old bulbs with 12v versions. The wiring on this bike is pretty robust (16 gauge, same as on my 12v XJ750) I don't see it struggling with the higher current.
Will this have any effect on my ignition system/points?
The hiss on the forks could just be the rubber gaiters, mine hiss and I know my seals are both air tight and oil tight.
But worth draining and replacing the oil regardless.Do the wheel bearings while you are at it if they are at all suspect, they cost next to nothing to do. You can drift them out with a long punch and tap new ones back in with a big socket.
It's also total mush, rebuild seals were dirt cheap, and if nothing else, I'll go with a heaver oil.
Will-do!
Already ordered some 320mm shocks. $90 shipped for the pair is pretty goddamn good!
ive heard that those shocks are hard as a rock and they arent all that strong.
the strong part came from guys putting them on 4 cylinder bikes an cracking them. i wouldnt think a 125 would do that. but they are stiff as hell. kinda just a shock for the looks.
good shocks that perform well start at about $150
If you've still got questions about converting to 12V, the Yahoo CB100/125 group has a pretty cool writeup. Its under their help files, seems pretty thorough.
So have you verified that 320mm is the correct length for the 125? Eye to eye right? My 40 year old shocks can't even handle my 145 lbs.
I can confirm stock length for the Honda 125 family is 320mm
I am awaiting the arrival of a replacement pair any day now.
50 GBP delivered (about $75)
They are made by the same company in Taiwan who make the reproduction Girlings for Brit bikes.
I've ordered them from a supplier who only imports from this source and vouches for the build quality.
I know they are not Hagon league units but are reputed to be sound oil filled dampers.
When they arrive I'll let you know the brand name.
DO NOT put heavier oil in your forks, it WILL make them unrideable and you'll feel every ripple.
Stick to 10w synthetic engine oil, 130 - 140cc per leg if I'm correct, and they will damp nicely.
I've gone with 140cc filling from bone dry.
4cyl bikes can break 650lbs with riders. The description for those shocks is "scooters, mopeds, ATV's" and has a CC suggestion of 250ish and under. So it's obvious that they shouldn't be put on bigger bikes, regardless of length
Erskine, let me know how they turn out. I'm interested in upgrading, but since these things are pretty generic, I want to hear how they work for the cb125 first hand.
I'm very interested in wet traction. I'm a year-round seattle rider, and this will be ridden in the city.
Also, it's not going to be a race bike. If I want to race, I can just take the bags off my RSV mille "daily"
Shocks arrived today and I fitted them but won't be road testing for a few days.
Good first impressions, much beefier than originals, no problem fitting.
On minimum spring preload they can be felt damping the rebound static.
They look good and unflashy, so at $75 delivered I'm initially happy.
Got my new shocks in. They're a little more orange-y than I was hoping, but it'll work fine once the new tank is dark green/gold pinstriped
320mm is is actually about 10mm longer than stock shocks on a cb125. But it still fit with no problem, the bike is just a centimeter higher now.
I had to remove the hand bar (no problem, the thing weighs about 180lbs, lol) and the chain guard to get the left shock to fit. I'm going to grab a chain guard from the parts bike in the shop and cut it up to fit.
It's stiffer, for sure. Closer to my RSV mille than not. But it's still definitely livable. And now I can run with a passenger without bottoming the thing's suspension out!
Stuck in limbo while I wait for the carb seal kit. I don't want to fiddle with -anything- else on the bike until I have it running perfectly.
How much interference was there with the chain guard? I commute on mine and would need to retain it to stay clean. Could it be worked around with the stock chain guard?
