CB125s build. "The Dishwasher"
Re: CB125s build. questions abound!
The CB125s is my favorite of the small Hondas and I've great memories of some long distance rides on my brothers CB-s. If I got my hands on one I'd leave the engine alone, but double the service intervals, spend time and money on bearings, bushes, tyres and suspension. Ace bars, rearsets.
The only serious modification i'd make would be fitting a hydraulic front caliper.
I wouldn't change anything else about the look of it though.
I'm going to change the exhaust setup, switch to a pod filter, and rejet it. That's probably all I'll do, engine wise.
Also going to add an extra tooth or two to the rear sprocket to get some more mph out of it.
I'm just about to re-jet my cg for a pod, it's the same carb as the cb. Initially going for a 105 from the 92. Roughly 10% + a bit more for a freer (but not open) exhaust and gentle gas flowing ( cleaning up the head with a Dremel, nothing radical)
The needle height setting seems to be best returned to it's original place. I'll keep you posted.
honeybadger said:
awesome. my stock jet is an 86, however.
I'm probably going to try a near-open exhaust
Try to keep some back pressure or you'll just be all noise and no action. ;)
yeah, only having power from 8-9krpm isn't ideal ;D I'm thinking of an "open" style exhaust that simply has baffles welded in to bring up the backpressure.
Also don't want to burn valves because of the stupid design of bike engines backblowing air into the carb to recieve a second load of fuel.
Do you happen to know what size the top and bottom shock bushings are? I'm checking out several pairs on ebay right now and want to make sure I don't end up having to swap bushings.
Honeybadger,
You'll have to let us know how the baffles work out for you if you decide to put them in with a free flowing exhaust. I recently bought a new pipe for my 125 and the bore on it is so big that its basically unrestricted, so I was thinking about doing something similar.
-jordan
12mm Top and Bottom.
Thanks for the quick response. Now back to your regularly scheduled programming.
Erskine said:
This is the regular scheduled programming.
Eh, I just felt bad for the thread hijack.
Rimmy said:
Honeybadger,
-jordan
I would love to see some ideas for custom exhausts. I have no idea how to put one together from scratch.
Hey Frank, I've just built a very effective free flowing but quietish one. I'll get something up for you.
The secret is to make the sum total area of the holes in a baffle NOT exceed the area of the pipe ID.
Use a bit of Pi R squared and there you go.
Do not be tempted to go over this area, it does not work, trust me! You may think more holes will help but it doesn't.
HoneyBadger,
I think we need to get together... You're in Seattle and I'm in Tacoma.
I'm trying to figure out how to convert my CB100 to 12v. I've heard that the CB350 stator will fit in our bikes
but havent been able to conferm it. Also what to do about the points/condenser and coil.
From what I'm hearing, nothing needs to be done outside of the battery, bulbs, and regulator. At least for the 125, though the 100 is just a smaller bore of the same engine, I think.
oldspice said:
HoneyBadger,
I have a cb350 stator in hand and im going to try and put it in one of these days. Also just bought a 12v reg/rec off ebay new for $25. I think im going to try and drop it in on my next oil change.
I'll be installing my regulator after I get tires, while the wheels are off and I'm rebuilding my forks.
Just FYI, it does work. Mine actually came off of a CB360. Bolts right in. Only modification I had to do was pull the wires out of the stock oil seal grommet and re-thread the 360 stator wires through it so it didn't leak where the stator cover meets the block and the wire goes through. Had the stock reg/rec for the same bike, ans swapped over the lights. It maintains 14.4v at the battery now at idle. SUCH an improvement. Went over to an RD350 coil with replaceable lead with custom bracket. Little joker is much better. (BTW I am running mine on a CL100, but yes, the bottom ends are identical.)
great to know! if I run into any problems with mine (it's always seeming to need more than 4-5k rpm anyways) charging, I'll definitely switch stators!
Riding this thing, I am loving it more and more.
Got my new seat in today! going to drop it off at the upholstry shop tomorrow with instrucitons on how to modify/recover it. Should have a sick new flat cafe seat in a week or so!
