cb175 high idle
need4steed
Active Member
I just picked up a 1972 cb175. It had been sitting for some time and one of the pistons and locked up. It wasnt anything too bad. I was able to get it free by shooting some knockers loose in there and then putting the bike into 5th gear and rocking to forward ever so gently.
I have the bike running, but not well at all. I did a quick clean on the carbs and hooked everything back up. It started right up, but the idle is really high (4500 RPMs) and then slowly comes back down to 2000. When i give it a little gas it is slow to respond and revs very slow. Im thinking i really need to do a lot better job cleaning them.....?
Also, where is the idle screw and the mixture screw on these. I have turned both of them and nothing has any affect on the idle. There are two that i am tlaking about. The one right in the middle of the carb that you can turn by hand, is the idle screw. the one that is closest to the air filters and closer to the bowl of the carbs is the mixture screw. I just want to confirm. What is the stock setting for both. I was able to find the idle (1800), but what about the misture screw. 1 1/8th turn out? thanks for your help.
the one in the middle of the carb is the idle screw. I think the mixture screw is about 2 turns out. And if the idle screw isnt doing anything, it could be the cable hanging up somewhere.
cool so i was right. Thanks for the very quick response. I will adjust the mixture screw 2 turns and make sure verything is clean and slides smooth. thanks again. will report back.
Well, after cleaning the carbs again and checking everthing the idle is still high. It will not go lower than 2800 RPM. the idle screws are all the way out and that has not an affect on lowering the idle. when i turn it in, the idle will rise. the mixture screw is two turns out. I also tried it with the mixture screw three turns and almost all the way out. NOTHING is working. it will idle great but when i give it gas it will rev up and come down really really slow.
Everything is as it should be with the carbs (i think). What else should i check for or do. Im at a loss here. thanks
The rubber intake boots arent leaking or have cracks...do they? that could cause a lean mix and possibly a high idle. Also check that the linkages arent binding.
Just checked both of them and they are both good. all parts are tight and snug. I also checked the cables, and they are clean and clear. they snap back real quick. I also checked the very top of the carb (where the cable goes into the carb) and everything is tight and down as far as it can go.....
When you rev it a little, you said it takes a little while to get back down to the 2800 idle? Sounds like air leak around the intake to me. Do you have the air filters off? You should be able to physically see the slides inside the carbs.
it doesnt matter if they are on or off. I thought the same thing about the air leak. but i have checked all the possible places.
I can see in there and the slides move in tandom and come right back down.
No, no. Maybe i wasn't clear, the filters shouldn't really affect the idle. I was just wondering if you could see the slides.
I have to ask - the slides are in facing the correct way? If the slides are down all the way, it's impossible for it to be idling high. The cable or the slides has to be hanging up some where.
The slides are in correct because there is a small square notch that runnings up the whole slide. On the opposite side, there is a angled notch for the idle screw to adjust the idle speed. You are right about something getting huge up, but what. I give up tonight and will check the slide travel tomorrow and report back. You have to be right about it getting hung up.
I will try and find out how the cable is supposed to be run under the tank. thanks again for the help.
Well I think it is fixed for the most part. I made sure the cables were not getting hung up. Check. I re-inspected the intake boots and tightened them down. Check. Now I can adjust the idle no problem. I can get it down to 1000 Rpms. I think idle is at 1800. Right?
I have the mixture screw out three and a half turns. Where is it supposed to be for stock?
So I can adjust the idle and ride it around the block without any problems. It has good pick up throughout the whole rpm range. It revs real quick and returns to idle faster than it did before. It's still a little slow but nothing terrible. At idle it surges a little. It will idle at 1800 and then surge up to 2400 and then drop. I think that means there is still an air leak somewhere. Right?
Does anyone know the or can confirm the stock mixture screw setting? I was able to find .875 turrns out. is that correct? thanks
7/8" of a turn out in 1973 with brand new Honda air filters, stock exhaust, and no wear on the engine?
Point is, it's your engine. The mixture screws need to be set to match what's been done to the bike. And even if somebody has the same setup, it can still be different when tuning.
Right now I'm at 3 turns out but it could be that I was tuning with just straight headers and no air filters. I was just tuning and not riding yet.
