need4steed
Active Member
I just picked up a 1972 cb175. It had been sitting for some time and one of the pistons and locked up. It wasnt anything too bad. I was able to get it free by shooting some knockers loose in there and then putting the bike into 5th gear and rocking to forward ever so gently.
I have the bike running, but not well at all. I did a quick clean on the carbs and hooked everything back up. It started right up, but the idle is really high (4500 RPMs) and then slowly comes back down to 2000. When i give it a little gas it is slow to respond and revs very slow. Im thinking i really need to do a lot better job cleaning them.....?
Also, where is the idle screw and the mixture screw on these. I have turned both of them and nothing has any affect on the idle. There are two that i am tlaking about. The one right in the middle of the carb that you can turn by hand, is the idle screw. the one that is closest to the air filters and closer to the bowl of the carbs is the mixture screw. I just want to confirm. What is the stock setting for both. I was able to find the idle (1800), but what about the misture screw. 1 1/8th turn out? thanks for your help.
