CB350 charging system issue
indianajonze
Active Member
I just put a new stator in my cb350 as well as doing the radio shack bridge rectifier mod. So both of those have been replaced. I have been told that with a good charging system I should able to unhook my battery while running and the bike will stay running. This isn't happening. It dies after about 10 seconds. Does this mean there is something still wrong with my charging system?
I have 14.5 across my battery while revving the engine which tells me everything is good but I just want to be sure.
Also, whats the best way to test a regulator?
Thanks in advance.
Pat
lets start with the easy one.
I'm no expert on electrical but it sounds to me like you already did.
All the regulator does is make sure that the voltage that's coming out of the rectifier doesn't get too high. So for something like this, the the faster the motor spins, the faster the magnet in the charging system spins, and subsequently, a larger AC voltage is produced by your alternator. This AC voltage is converted to DC by the rectifier and then smoothed out and stabilized to 12-15 or so volts by the regulator. So if you stay at a particular voltage regardless of rpm, then it sounds like your regulator is operating as designed.
I'm not really sure about the other question. Mine has always operated as the way you describe it (i.e. with the battery unhooked=very unhappy engine) I also did the stator + rectifier/regulator upgrade.
But here's a way to test this
disconnect the regulator/rectifier wires from your harness.
Hook up the battery by itself to the harness.
So now you have 2 exposed wires, coming from the charging system and these will not actually charge the battery. put your voltage tester on these. you should read 12-14 volts or so.
another way would be to disconnect the wire coming form your upgraded rectifier/regulator and put an ammeter in place between the positive of the battery and the positive cable from the rectifier/regulator. If you can measure a current when the bike is running, you're charging. Hopefully this current is greater than the draw current of the rest of the system. (this depends on the coils you have and the state of your points/harness/etc, but for me and my 4ohm coils, i pull about 3A) (I=v/r , I = 12(*numCoils*percentTimeClosed)/4 ) I = 12 (*2 *.5) / 4 = 3A
I don't know if any of this helps. I'm by no means an expert. And this could be wrong so take with a grain of salt.
Hi Pat,
I believe the stock charging system on a CB350 does not charge below 2000 RPMs. Therefore, a battery is needed to keep the thing going at idle. I have read that folks who use a capacitor in place of the battery have to occasionally goose the throttle at idle to keep the thing running, so your bike dying with no battery seems very normal in light of this.
In automotive applications, it is a very bad idea to remove the battery from a running vehicle, as there is no longer a load to regulate the charging system and provide a buffer against voltage spikes. However, since the CB350 uses a permanent magnet charging system instead of an alternator style system, this might not be such a big deal.
Dime City has this upgrade kit:
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-electronic-parts-ricks-electric-hot-shot-honda-cb350-cl350-cb360-cl360-charging-kit-99-101.html
I think it provides better charging at lower RPMs than the stock system, so if you're looking to upgrade your charging system, or remove the battery/downsize it/replace it with a capacitor, this might be the ticket.
TL;DR: I think your charging system is fine, and I think it's normal for the bike to die at idle without a battery connected.
