lets start with the easy one.
Also, whats the best way to test a regulator?
I'm no expert on electrical but it sounds to me like you already did.
All the regulator does is make sure that the voltage that's coming out of the rectifier doesn't get too high. So for something like this, the the faster the motor spins, the faster the magnet in the charging system spins, and subsequently, a larger AC voltage is produced by your alternator. This AC voltage is converted to DC by the rectifier and then smoothed out and stabilized to 12-15 or so volts by the regulator. So if you stay at a particular voltage regardless of rpm, then it sounds like your regulator is operating as designed.
I'm not really sure about the other question. Mine has always operated as the way you describe it (i.e. with the battery unhooked=very unhappy engine) I also did the stator + rectifier/regulator upgrade.
But here's a way to test this
disconnect the regulator/rectifier wires from your harness.
Hook up the battery by itself to the harness.
So now you have 2 exposed wires, coming from the charging system and these will not actually charge the battery. put your voltage tester on these. you should read 12-14 volts or so.
another way would be to disconnect the wire coming form your upgraded rectifier/regulator and put an ammeter in place between the positive of the battery and the positive cable from the rectifier/regulator. If you can measure a current when the bike is running, you're charging. Hopefully this current is greater than the draw current of the rest of the system. (this depends on the coils you have and the state of your points/harness/etc, but for me and my 4ohm coils, i pull about 3A) (I=v/r , I = 12(*numCoils*percentTimeClosed)/4 ) I = 12 (*2 *.5) / 4 = 3A
I don't know if any of this helps. I'm by no means an expert. And this could be wrong so take with a grain of salt.
