CB350 Sly... Now with 2 finger braking!!!
Re: CB350 Sly... Project dead
Wouldn't the sleeve push down and level when you torque the head? Or place the cylinder upside down on a hard, level surface, then use piece of wood and hammer and pound the sleeve back in.
When the cylinder is cold you should not try to move the sleeve.
when hot it will slide with out much effort
thanks guys! sonreir put me on to heating it up... torquing cold did nothing... in the oven as we speak! I'll keep you posted!!!! there may be hope yet!
I hope you had a couple of wood blocks ready and welding gloves to lift it out of oven, if you stand it on spigots they will slide up further
Usually needs around 350~400f, I've done a LOT of big bore/liner changing ;) 8)
That tends to happen with Honda barrels if the sleeve interference fit is a little on the light side. We have had a couple that happened to.
If you want a laugh, put a spare set of Honda twin barrels out on your driveway on a really hot day (right way up) and check them after an hour or so. Chances are the liners will be moved a long way. Sometimes they will fall out.
You can guess how I made that discovery. :-(
thanks for all the support everyone! it looks like we got the fix on this problem, subject to final inspection tomorrow when it's cooled down. i was freakin' out a bit! ok, a lot! update tomorrow!
LA Sleeve recommend 0.004" interference but I find that's too tight so use 0.003"
Awful lot of earlier Honda's only had 0.001"~0.0015" interference (I've measured quite a few)
Re: CB350 Sly... Project possibly back on track
well, the liners did slide ALMOST back into place when i heated them up. i tried again with a different jig so there would be more weight on them and it got a bit better but they're still up by .004" at the high spots. does anyone know how much irregularity a head gasket can tune out? am i close enough to make it up with gasket goo?
thanks again for the support.
They will drop when engine gets hot so you will probably need to re-torque head after first run.
The alloy shrinks further than the cast iron so you chill top of cylinders while hot, I use an old baking tray full of ice so top of block will cool before bottom, I also made a fixture to clamp liners on the XS650-800 conversions I've done
ok, both liners are out. i thought maybe there was some crap in the seats that was keeping the liners up that extra 4 thou, but no. so now i have to decide if thats close enough or if i should be trying to get the liners trimmed. i dont really want to do a bunch of unnecessary work if the gasket will take up the .004" difference, but i dont want a motor that weeps oil constantly either... and meanwhile i scorched and discoloured my engine paint, so i have to go back to the blaster and repaint as well...
damaged the paint? you didnt use a torch did you?
uneven heat is a really bad idea
400* in the oven for a while then literally tap them into place, job done
DO NOT SHORTEN LINERS
They WILL move when engine gets hot and they are under pressure, then they will leak.
'Liner drop' is pretty well know by people who do big bore/liner swap conversions
I've only ever had one drop far enough to cause problems which is why I made fixtures to keep pressure on liner while cooling
ok! I was just coming to this on my own, because the motor ran previously and I've done nothing to the cylinders other than paint them. it just struck me as odd that they don't sit flush. i get that the metal part of the head gasket will seal between the liner and the head regardless, so it's not a compression issue, but it seems like a recipe for an oil leak when you have the oil feed for the head passing through the gasket and the head doesn't quite meet the deck of the cylinders at the points where you have an oil passage! anyway, I shall now press on and see what happens! thanks for the input PJ!
deepwater, duckboy and rosepunk, thanks for the kind words! i hope i can get past this motor issue and get back to the fun stuff soon, maybe get some pics happening again!
ya they were heated in the oven, but repeated heating past the cure temp caused the paint to yellow...
the 400º oven trick works, i was just confused by the fact that when the liners are fully down they're not flush with the aluminum part of the cylinder.
Re: CB350 Sly... Pod filter? hell yes!
ya that's right... i'm rockin' a pod filter... does this mean i need to rejet? ;D
Liners will move when engine gets hot and has pressure from head holding them down
Breather pods don't count ;D
