CB360 box build - Project Junebug
Re: CB360 box build - nearing completion
FIRST SIGN OF LIFE
it's the little things.
Well I don't know about that, but I'm getting closer.
Gonna see if I can get her cranked today. I've been reading good things about rotella, so I guess that's the oil I'll put in there.
Any suggestions about additives for a first run in 20 years?
Btw... I think my clutch plates may have flash rusted together, I put them back in dry.
I can probably make Trek flip out, but I am not yet sold on the Rotella. ;D I have heard another side too. I have some adjustments to make, then I'll open her up to inspect, but I may switch out mine.
I think the only thing keeping the bike from cranking right now is the paint on the super bike bars. Can't get the stupid starter switch to ground
I use the full synth Rotella in all my bikes, not having any problems with gear change or clutch (after fitting heavy duty springs)
I was using it at least a year before telling Trek about it
You have the handlebar mounts grounded to top yoke plus forks grounded to frame?
Yup, everything is grounded but the switch. I just need to brush off some more paint. I have continuity from frame to bars, top triple, forks, headlight nuts, etc.
Also, my brake light only comes on in position three of the ignition switch, the "start" position. It should be on in position two as well, correct? May have a faulty ignition switch.
The 'brake light' in pos 3 is the parking light. Brake light should be way brighter than park/running light
I really doubt you have a faulty switch, more likely you have things wired wrong somewhere
I meant the parking light/running light... Im using an original harness and tested the light on the battery to figure out which wire was brake and which was running prior to install. The brake light is connected to the green/yellow striped rear brake switch, running light wire to brown, and ground to ground. The black line on the brake switch is connected to the four pronged connector that is subsequently hooked up to other stuff (correctly, I'm pretty sure)
I think I have a faulty brake switch... I'll test that when I get home, but what I was asking is if the running light should come on with the ignition switch in position 2.
Stock Honda, Black is 12v live feed, aftermarket it may be live or ground. Your tail light wiring may not match stock harness?
I believe you cleared that up. I don't know why I said ground to ground, I had it plugged black to black, which is the 12v...
In the meantime, I have decided to undo the loom and rewire it. Anyone have a wiring diagram for no blinkers and a combo reg/rect? I think I'm doing fine, but it would be nice to know I'm not making any stupid mistakes. I'll draw a diagram up and present it when I'm done and see what y'all think.
There are multiple wiring diagram's, CB175/200, 350, 360, DOHC 450/500t all use similar generator system so wiring is the same.
I don't think I've drawn up a diagram for about 43 yrs though :( (feeling old now)
This was the wiring diagram I WAS using... It's straight out of the clymer manual
But this diagram is much more detailed. The clymer diagram is actually missing some stuff.
My left hand controls are from a 1977 cb750 I'm pretty sure, so the wiring is off. Gonna have to split it to figure out what's what. Once I get the money I'll buy something that's just hi-lo and horn.
Personally I use a newer model 5 wire regulator/rectifier, (CB400/450T)
It cuts down on a load of extra wiring.
The CB750 switch uses the same colours as earlier models so shouldn't be an issue
Yessir, I bought mine from Sonreir at Sparck Moto. It definitely neatened things up and was super easy to install.
The three wires on the left are my mystery wires. Below them is the switch diagram.
And here is the switch itself. It actually IS a 360 switch, it's just nutty.
Are they orange or brown?
Orange with white stripe is for running light and not needed. Brown.brown white are for tail light and front parking/running light (front isn't fitted on US models)
I don't remeber dark blue/white, high beam warning? (it's headlight related)
Blue/white is the headlight main wire. It feeds the dimmer switch. Hook it up to a black in the harness. Some models, this would be a black/yellow wire.
