deviant said:I can probably make Trek flip out, but I am not yet sold on the Rotella. ;D I have heard another side too. I have some adjustments to make, then I'll open her up to inspect, but I may switch out mine.
plagrone said:I think the only thing keeping the bike from cranking right now is the paint on the super bike bars. Can't get the stupid starter switch to ground
crazypj said:You have the handlebar mounts grounded to top yoke plus forks grounded to frame?
I meant the parking light/running light... Im using an original harness and tested the light on the battery to figure out which wire was brake and which was running prior to install. The brake light is connected to the green/yellow striped rear brake switch, running light wire to brown, and ground to ground. The black line on the brake switch is connected to the four pronged connector that is subsequently hooked up to other stuff (correctly, I'm pretty sure)crazypj said:The 'brake light' in pos 3 is the parking light. Brake light should be way brighter than park/running light
I really doubt you have a faulty switch, more likely you have things wired wrong somewhere
crazypj said:Stock Honda, Black is 12v live feed, aftermarket it may be live or ground. Your tail light wiring may not match stock harness?
