Sonreir said:You wanted to go to a 378 anyway, right?
Sonreir said:I don't think you'll be able to make a decision about any of those things until you get the engine apart and specced out.
Worst case scenario is you have to bore the jugs, get bigger pistons and rings, recut the valve seats, and get new valve. Best case scenario is hone the bores and get new rings, and lap the valves. Reality is likely to be a mix.
Sonreir said:Or you could get cheap and just peen it. It's aluminum, so you're not going to get hot spots like you would on an iron head.
crazypj said:Not a problem, skim 0.010" off head, mount on a rotary table and re-machine the 'squish' band.
I've done CJ250 (56mm bore) to 70mm bore that way![]()
If you had clearance on intake valve seat you could just flycut the clearance to get back to bore size
