thrillseeker
Thank you for the pointers on the crankshaft, PJ. The metal bits are in the larger hole which I'm pretty sure is the oil passage. I'll take your suggestion and try to get them out and wash with diesel fuel. My original assumption was that the metal bits were actually shavings from in the crankshaft bearing, rendering the bearing/crankshaft useless. After I get them out, I'll try to see if they may be from something else. Any ideas off the top of your head what the shavings would possibly be from? Maybe that one spot was a bottleneck and the oil flow caused them to collect in that location?
