Looking forward to getting back in the shop, but it looks like there's a chance of rain this week/weekend :-X
So I ordered the jets (120, 122, 125) but they weren't here by the time I went in to the shop, so I decided to check the intake manifolds with carb cleaner. Forgot my key
so didn't do much. I did look into the exhausts, nothing clogging them but the baffles. Just curious, not saying I'd do this necessarily, and I know it's different with different exhausts, but how much of a change in volume would I expect with the baffles drilled out? Didn't learn much about the fork lock, I emailed someone (motorcyclekeys@gmail.com or something) who I got my ignition key blanks from and I'm trying to see if I can get the fork lock functional, but didn't realize the lock code is inside so I guess I have to take it apart? He also said if my ignition key is the original it should work with the fork lock but crazypj you said that wouldn't work? I guess it couldn't hurt to try next time I'm in the shop though. Of course since I didn't have the key I didn't do anything with the fuel/air mix either, so my checklist is:
1. Spray carb cleaner and check the intake manifolds
2. Play with the fuel/air mix and idle, see if that does anything
2.5 (I'm going to assume I'll need to change the jets after this anyways, so start with 120 and go from there)
3. Check plugs (which means I have to go buy more plugs, $9 for two adds up!)
4. Most likely, repeat step 2.5
