41mm for the gl , 33 for the cb and there is a bearing swap .
Now the question is why the GL1000? Much better available front ends are available .
The Katana as well as the FZR front ends were lighter , less unsprung weight , better brakes , more available and once again unless you already have a GL front end , why ?
I'm using Katana front end on mine.. Race tech internals as well. I believe the triple yoke is a perfect match. I am using a CBRrr triple so I'm needing machine work.
My mind is divided between using parts from that era to get my dual disk set up or going with something more recent (R6 or Katana). I prefer a solution where I don't have to machine caliper mounts.
Not sure about the offset, but I'm using a bunch of different things but I will only need some spacers for the calipers, everything else should line right up
Keep in mind that if you use the early GL spoked wheel front end, that the wheel is much wider than the CBs. Its also alloy iirc so it won't match the stock steel rear. Easily fixable with an alloy rear hoop, but it is something to keep in mind.
