CB450 Project seized motor and all! *Need some wisdom*
Thanks Worst. Makes sense but I had never dealt with a broken rod so I appreciate the info. Still at work. I'll check when I get off!
If you bust the case leave the two crank cradles in place, you will see what I mean when you get in there.
Everything else can go into a box and bags and such.
Well, 2 things happened tonight:
I got the motor broken from being seized but the top of the piston is a bit textured now. And I was hitting a wooden dowel and it broke and I hit the motor as it broke.
Im a little concerned with the seal and it leaking oil and is there a way to smooth these piston heads. They arent tooo bad, the one in the pictures the worst.
Well, since it was rusted in, the next thing to do is take the cylinders to a machinist with the manual so they can get an idea of specs. IF its OK to be honed and re-rung then check the piston dome for any mushrooming that you might have caused between the TOP ring and the top of the piston, if there is any you probably should toss them.
IF the cylinders need to be bored to get rid of the rust then you will need to buy the correct sized pistons and rings.
What do the bores look like?
As far as that little dent, just file/sand any that might stick out or up into the gasket or piston.
So I took the cylinder and used a honing tool and removed surface rust from inside the cylinder. There is still some pitting on the inside of the cylinder very light but not completely smooth anymore.
I then did a light cleaning on the piston heads the locked piston head was a bit dirtier and will not move smoothly in the cylinder, I put the jug back on and the left piston will not slide into the cylinder more than 1/2 an inch.
Any tips? I can spend any cash due to rent coming up soon. If you guys have any tricks let me know
Might have beat the left one up a bit, look it over with a caliper. I messed mine up pretty badly beating it out.
