Much easier than dealing with the housing, easier to get a filter, extra oil capacity....you need more?coyote13 said:Thinking too much, why would you even want to?
MR915 said:I have done it....works well.
- Modern filters incorporate anti-drain back valve (not in OEM design)
- Many feel that modern filters offer a more reliable pressure relief valve than the OEM design.
- Permits the use of these economical, readily available auto spin-on filters (not included in kit). All of the Fram filters below have an 8-11 psi by-pass valve and anti-drain back valve in the filter.
- Fram PH2951
- Fram PH3600
- Fram PH3614
- Fram PH6016
- Other verified filter cross-references listed for convenience. All of the filters below have an 8-11 psi by-pass valve and anti-drain back valve in the filter.
- CarQuest 85348 (Blue Box Premium Model)
- NAPA Gold 1348
- Purolator PL10241 / PL25230
- Mobil1 M1-102
- Bosch 3330
- AMSOil SMF 108
- Baldwin BT223
- Hastings LF157 / LF134
- K&N KN-174C
- Purolator L10241 / L20064
- WIX 51348
MR915 said:Much easier than dealing with the housing, easier to get a filter, extra oil capacity....you need more?
