CBigBore 360 engine in the making
Plus, waiting for the parts gave me the time to get rid of the lunar landscape on the pistons. A step I would've skipped in pure overexcitment
This is excellent !
takes me right back to my 390 build a couple of years ago, except you’ve gone in to way more detail than i did.....
i was very pleased with the performance of the 390 motor, so hopefully you’ll be rewarded for your efforts
steve
This is excellent !
steve
Thanks, Steve! Very much appreciated!
Decided on building the engine already, only to be rushed into the hospital a few days later. That was the exact moment I made the decision to use this to keep myself busy while I was on the mend... And suddenly we're all stuck at home with the current pandemic dumpster fire. So timing - all things considered - was actually not all that bad :)
Now I'm just hoping it won't blow up rightaway :p
Hard to tell from the pics, but how's the desk height? Is it flush with the head or is it higher?
Good point Matt, the deck height is important.
i had a copper base gasket made to adjust mine after a test build showed the pistons were too high.
steve
Well, fresh piston rings gapped and cylinders on. New problem. Cam chain tensioner is really, really tight.
Should drop in to about the same height as the cylinder head surface.
Any guesses?
Any guesses?
Two things. Did you pull the tensioner push bar out as far as possible? And make certain the tensioner slipper is seated in the socket on the tensioner arm.
Any guesses?
Looks correct to me. It should sit about 1/2" to 3/4" above the head surface. Make sure to loosen the cam chain tensioner bolt before installing the top bracket.
Last time I get to see those superfinished rocker beauties.
Did another bit of bullshit rotational mass reduction
Can't help it
Busy day considering I wanted to swap the broken pulse generator on this puppy today too.
Been set for a year, faulty electric goose chase... But she's thumping again!
But to finish on the CB... Couldn't help but mount the carbs and filters.
It is a pretty engine, isn't it!
Now need to find time to get mounting...
