Thanks, Steve! Very much appreciated!This is excellent !
takes me right back to my 390 build a couple of years ago, except you’ve gone in to way more detail than i did.....
i was very pleased with the performance of the 390 motor, so hopefully you’ll be rewarded for your efforts
steve
Good point Matt, the deck height is important.Hard to tell from the pics, but how's the desk height? Is it flush with the head or is it higher?
Am counting on that! Just got new rings in, so I can get to it this weekend, though I'm hoping to fix the NX650 Domi before monday as well...Loving this, she’s going to look mint
Squish came in at a perfect 1mm. Pretty darn happy with that!Hard to tell from the pics, but how's the desk height? Is it flush with the head or is it higher?
Two things. Did you pull the tensioner push bar out as far as possible? And make certain the tensioner slipper is seated in the socket on the tensioner arm.Well, fresh piston rings gapped and cylinders on. New problem. Cam chain tensioner is really, really tight.
Should drop in to about the same height as the cylinder head surface.
Any guesses?
Must've messed up somewhere. Followed all the steps, did them again... Just fineTwo things. Did you pull the tensioner push bar out as far as possible? And make certain the tensioner slipper is seated in the socket on the tensioner arm.
Any guesses?
I must've done something wrong. When I tried it again, it was fineLooks correct to me. It should sit about 1/2" to 3/4" above the head surface. Make sure to loosen the cam chain tensioner bolt before installing the top bracket.
It is a pretty engine, isn't it!
