How were they honed and has it been measured since honing?
If the measurement was done 'old style' with a feeler gauge down side of piston and you only have 0.002", pistons don't need changing
If it was done properly, measure piston diameter, measure cylinder at multiple points with bore gauge/micrometer and it's only 0.002", you definitely don't need new pistons but probably should do rings
The YR5 is the 200cc twin?
If so, I believe DT100 pistons fit which may be easier to find as it was made well into the 80's
