Changing pistons
ty.man
Active Member
What all is needed when changing pistons? i know the piston and rings but do i need new circlips or needle pin bearings? thanks yall
What bike? And never reuse circlips. Too cheap not to replace. If gudgeon (wrist) pins are good, you can reuse.
Early 70's Yamaha r5. Thanks for the input. I couldn't remember what the gudgeon pin was called. Do the circlips and gudgeon pin need to be specific for my bike?
yes, have to match the piston and your conrods
Alright so my jugs were measured. Worse spot was off by 2 thousands of an inch
The Guy told me new piston rings and I should be good but they must be the original pistons so I figured I'd replace them. Got the jugs honed so now my question is can I just get a standard piston kit and put it back together? I'd imagine so but just checkibg first. Thanks
How were they honed and has it been measured since honing?
If the measurement was done 'old style' with a feeler gauge down side of piston and you only have 0.002", pistons don't need changing
If it was done properly, measure piston diameter, measure cylinder at multiple points with bore gauge/micrometer and it's only 0.002", you definitely don't need new pistons but probably should do rings
The YR5 is the 200cc twin?
If so, I believe DT100 pistons fit which may be easier to find as it was made well into the 80's
R5 was the 350 twin on which the RD350 was based. Pistons are hard to come by but I don't know about ring availability. It's possible that RD350 may have the same rings but you would need to check. Yamaha tried a few different shapes of rings over the years.
Modified DT175 pistons should work, pretty sure I read someone has done it?
It may have been for an overbore motor
thanks fellas. ive found and ordered pistons and rings. im getting circlips next paycheck as well as pins and small end bearings if needed. Got the side covers, heads, and cylinders off for paint and that was a disaster yesterday. Didnt know you need heat for the wrinkle paint to work so it looks like shit, im just gonna go over it when it gets warmer. Motor should be buttoned up within a month or so. Oh ya and i was told to replace the seals for peace of mind. Do the cases need split for this? thanks
Yes, but it's an easy job. Longest part is cleaning the case halves so they can go back together perfectly. Bottom end seals MUST be replaced. They are cheap and available and easy to change. No need to split the crank to replace the center lab. seal. They almost never need to be replaced.
