cl350 wont even do 60mph...PLEASE HELP
snolte00
Active Member
Ok so I just went to pick up my bike from the shop and theyve done a less than amazing job. The issue that Im posting about is this;
After a certain point in each gear it just wont give me anymore. I dont mean I have it redlined, I mean this thing wont do 60mph. I have pods, I cut the exhaust short, and the carbs are jetted properly. The thing is loud as hell but just crawls when it comes the top end. The power seems fine on the lower end but just has nothing else to give me. So I promptly limped it back to the shop and kindly asked them to fix it. Please tell me what the issue could be.
Thanks
Stephen
How short did you cut the exhaust? Is it just straight pipes or do you have mufflers? Also wondering if your advancer is working correctly? Worth checking since it only take a minute. Clutch adjusted correctly?
The exhaust is about even with the pods. They are straight with home made baffels. The shop checked all of the basics when they had it but who knows... The clutch is another problem. When I put the clubmans and the new levers on the clutch lever was really tough but I didnt mess with it too much. Today when I was riding it from the shop the clutch cabel broke or popped out or something to where the clutch didnt work. So I dont know. The power problem was before the clutch cabel failed so...
Heres a picture for reference.
The exhaust is no shorter than many others I've seen and the carbs were just rebuilt spot on last week. How would the clutch play a role as stupid of a question as that may be.
If the clutch is not adjusted correctly, then it may be slipping and so you won't be getting all the power to the back wheel. Do you RPM's continue to rise but the bike just not get any faster?
No not really. It just feels like its topping out at a point where it shouldnt be. Like in 5th I think I made it to 45-50mph and then it just had nowhere else to go. I'm so confused. Could it be an issue with back pressure? Or lack of with the exhaust?
I mean the shop spent a lot of time getting the jets proper for the pods and exhaust. I guess they could be wrong but I'm still thinking with is a different issue because the power is good in the first few gears. It just literally tops out at 50 with a tailwind...
Well these bikes do hate pods and short exhaust
And you really have not answered the question at hand about the jets...
Properly to professional people is they changed all the jets a few times and confirmed that it was in tune on a dyno....something tells me that's not what you had done.
If its the clutch the RPMs would be high when you hit that speed wall. If not its not the clutch.
Did the bike run right before you decided to "improve" it with these mods? Emgo cheap crap pods?
What jets are in it now?
Also just because you saw someone on the interwebs with the same mods don't assume it worked for them. Seen a few bikes that made the rounds of the blogs and never ran at all and were nothing more then an art project.
Bikes don't get built on line
I agree with the crap pods statement but hey I was on a budget. The shop that I took it to pretty much only works on these bike so I can only assume they "properly" jetted it. As for it running before everything, when I test rode it before buying it, it ran better than it does now as far as the top end goes. Its at a higher RPM when it runs out of power but it should have a lot more room. And I dont know specifics on the jets just yet.
I spoke to a guy with the same year and same exhaust and pods that had his at or over the ton mark. I just know that theres obviously a problem and I cant figure it out.
No money isn't a good excuse to doing poor mods.
I assume its the carbs.
Check the diaphragms.
But as always you need to go over the basics.
Spark?
Compression?
Do you have any tools or skills to check yourself?
Do you have a factory manual?
When talking tuning it's been covered many millions of times here and other placed on line. There is not answer or real help to be had, it's trial and error.
Either learn to tune or find someone that can and pay them.
Sounds like you are trusting them to do this tuning properly, but just like everyone and their mother wants to build a cafe, a million shops are jumping on the bandwagon too.
Like I said, the carbs were fully rebuilt less than a week ago. The shop specializes in cafes and the back pressure and clutch adjustment make more sense.
They obviously don;t have a clue what they are doing if they gave you back your bike "fixed" and it tops out at 50.
How did they do the jets if they didn't test ride it?
Check your carb sync. They have to be real close to perfect.
They did test ride it. I dont know to what extent though. I agree though, I was beyond pissed after all this happend. I paid for 10hrs of work just to leave it there and scream the whole way home.
It can't be the clutch unless you are at high rpm and not going to speed.
If you are going to wide open throttle and the bike is not reving past a certain RPM/speed then it's something else in the tune.
Just saying fully rebuilt really doesnt mean much and it's clear that something is wrong.
