cl350 wont even do 60mph...PLEASE HELP
snolte00 said:
Like I said, the carbs were fully rebuilt less than a week ago. The shop specializes in cafes and the back pressure and clutch adjustment make more sense.
Snolte, I just want to clarify : who rebuilt the carbs? The shop? I'm sure they are cleaned out with any worn parts replaced. Maybe even new jets installed throughout - but just not the proper jets.
Forget about anything you've heard about an engine needing back pressure. It's more about "tuned length". The problem with cutting the mufflers off is your exhaust is now tuned for an RPM range that the engine will never reach. If everything else was running perfect and you leave your exhaust cut short, it will only knock off about 5 to 10 MPH off your top speed (just an example).
What everybody is trying to say is that it sounds like your motor is running lean. Whether it's from your jets being too small (most likely), float levels being way off (running dry at high rpm's), clogged fuel filter, etc,etc. We just offered advice as to what the problem could be. The ball is in your court - either take it to a shop to fix it (I personally don't recommend this) or learn to do it yourself.
if they got the jets proper, it wouldn't top out at 50, unless there was another issue, which they should have addressed... I don't see a reputable motorcycle shop sending a 350 out the door that would be smoked by a 125... if it were me and I paid them to tune the bike, I'd bring it back
snolte00 said:
I mean the shop spent a lot of time getting the jets proper for the pods and exhaust. I guess they could be wrong but I'm still thinking with is a different issue because the power is good in the first few gears. It just literally tops out at 50 with a tailwind...
If They didnt ride it or dyno it, than how did they know the jets were right....? your running out of fuel, adjust your floats to deeper than stock (raise them by a mm at a time)....with pods and that exhaust, any jet larger than stock will work, work great no, but work. I know....:/ I had the same problem..... when it reaches about 85-95, thats it. Now rejet to make it "crisp") got "stuck" around 70.
sorry,with this build..
it's a 175, but same desin. Notice the pipes, and pods.
To clarify, the shop did all the work that I couldnt do. They rebuilt the carbs, they did all the tuning, they test rode it. They are in the heart of the city so its possible they didnt take it out and really run it. It runs fine in the lower speeds and if you arent really pushing through the gears like I made sure to do, you may not notice the lack of power at the upper end of each gear. And then in 5th, it just has nothing left. The shop almost exclusively works on 70s jap bikes and specifically the cb/cl series so I can only trust what they say. So to clarify, the general idea is that its not the pipes/ lack of back pressure? Its more a tuning/fuel issue? I appreciate all the answers and help Im just really pissed off at the situation and hate not having answers.
Thanks
Stephen
No, you have added more then one variable to the equation so there is more then one problem.
The cheap pods decrease performance as does the way to short pipes. These "mods" losses can be tuned in such a way to limit the damage, this is done through time, jets and trial and error. There is no internet magic that will let you know what jets or home made back pressure increasing washers to weld in to make it perfect again
Also we are all assuming that this motor was 100% healthy to start with and not some "barn find" that ran when parked 30 years ago and was just started and then hacked into.
Many MANY things could cause the vague symptom of loss of MPH
While I dont mean to sound like a dick and put you down for not knowing alot about tunning or engines, everyone has to start some place. BUT you are clearly bitting off alot. You have placed alot of stock in a "shop" and thats really the only thing that you can do if you dont have the time tools and skills to do it yourself, BUT they did give you a bike back that doesnt work....
It no excuse at all that they couldnt stretch the bikes legs and thats how they didnt know.
Just to rule it out, has a compression test been done? If i missed that, my bad. In my opinion, that should be addressed first. You can guess & follow calculations for jet sizes all day long, but if you have leaky rings or valves you'll get nowhere.
Like surffly mentioned, there are too many variables released onto this bike. At the very least, make sure the engine is able to SUPPORT COMBUSTION by doing a compression test. Then have fun figuring out back pressure & jet sizes.
I've never chopped my exhausts off, so i'm not familiar with the loss of back pressure.
Looking too deep in my opinion... I'd look, but after I had cause too. Like smoking like a mother fucker, or, oil dripping out pipes... But he say it runs great for 35ish miles. Please loosen your gas cap next time this happens. while it's full, it'll push gas with the fumes and expansion. But at 3/4 full, there may not be enough volume of fumes and fuel. Crack your gas cap, it might be vapor locking.
vapor locking is when the fuel gets hot in the lines
gas cap would just be the tank not doing its job and venting.
But the vent would happen if you were riding around all day at 4 miles an hour, not only when WOT in 5th.
It is a bit overthinking the issue to go right to compression, but then again thats something that takes 6 and a half minutes to check.
I know what it is. but the same effect can occur when there is vaccum, which is what is created by what you describe, no? ya, vent the gas cap! better than suggesting a compression check, than probably a rebuild when he see's less than new #'s.
And a 35-45 mph loss would be one of the last indicator's that the motor was shit (or low compression) right before it BLEW.
Swapmeet Louie said:
Surffly, give me some credit...? please...
I know what you meant and agree with you, we are just debating semantics now
I just like to use the right terms for the guys that dont know the difference
And like we all have said, the OP has more then one issue, some he created with poor mods, some might have just been there due to age of the machine.
There will be no real answer to the OP because he is not the one doing the work, he is trying to discribe his issues to the interwebs and not really in a position to fix it himself.
Fuck, my bad... the 35mph reference was to another thread...
Thought that was this thread....you know the one with the traditional cafe 350 that should run a ton all day......
Also in my experience things run faster....right be for they die
Side note to the OP
How do you know that you are only doing 60?
A 350 on a perfect day when new would not really want to do 100....and after 40 years and performance decreasing things done to it....
Agreed! he has created a monster by not concurring 1 mod at a time. But low compression I am willing to bet is the least of his worries... He would have crazy piston slap, and the bike would be next to impossible to start, if the compression was low enough to be this effective.
What ever it is, it's "tiny". I'll bet less than a $20 fix. If the motor is indeed sound, which he has said nothing of weird noises or visual signs of fuct.
Compression was checked just out of basic practice and came out really well. The bike starts first kick almost every time. I can agree that I may have caused some of these problems but I'm not an idiot so dont come at me like one. This is my first vintage honda and I took the go big or go home approach. The pods are commonly used and although cheap, shouldnt be the problem here. The pipes could be contributing but just like Swapmeet Louie said, he basically ran the same set up just not as short. I think it has to be a matter of tuning. The motor itself is sound and ran with much more power when I got it 3 months ago so the problem is contained within something the shop or myself did. The shop is running back through it this week so I should know something soon hopefully.
"came out really well" again what does that mean? These are machines that have a spec that they need to reach in order to perform.
Pods are commonly used and commonly have problems, even more with the cheap ones.
Really what myself and others here will try and talk about is the HUGE pit falls of the "go big or go home" approach to this, even more so when you are relaying on others to fix the bike
Just seeing it done by other sheep on the interwebs doesnt mean that it really worked.
A ton of "art projects" have been built and lusted after, but they never work as motorcycles
I dont know if this ever actually was run....or ridden, I know for all of its blog rounds it was not running
Really the 4 pages of dialog have offered little information for people to try and help you, and im sure that there has been little said that really will help you fix what ever issue you have. There are not alot of "could" things that are going on, the cheap pods and short pipes ARE hurting the performance, as I said this can be limited by proper tuning. But that is with everything is perfect. Old bikes can run fine one day and not the next, its the nature of things. Maybe you have a coil wire grounding funny, or the points are fucked, or any one of a million other service things.
What is your actual plan to make this bike work as a motorcycle?
It is just to keep going to the same shop?
Is there a new shop you could try?
You claim not to be an idiot, so do you have the time/skill/tools to try and sort things yourself?
