Lucas Denton said:i noticed is that there are only like 2 or 3 strands of wire in the cables themselves im sure there should be more.
Redliner said:The labeled marks are the timing marks for the left cylinder. The unlabeled marks are for the right cylinder. The first is the idle timing advance mark, followed by the T for TDC mark.
Believe me, the cylinders are not at actual TDC at the same time. Why would Honda mark a wheel for the exhaust stroke?
If somehow you still can't believe this, look inside a spark hole and turn the motor until an exhaust valve is open. Leave the engine at this position and check the other cylinder. Do you see an exhaust valve open in that one too?![]()
Redliner said:Guh, once he said the marks were 180º apart, I don't know where my mind went. There's no way the advance is 180º away though...right?
Both cylinders reach "TDC" at the same time, but only one is on actual TDC, meaning the top of the compression stroke. At this same time, the opposite cylinder in on the exhaust stroke.
Sonreir said:No effective difference between TDC and "actual TDC".
