Coil for 1972 CB175
Yeah... that would be a bit of a "no-no".
Also, FWIW, the feeler gauge should be dragging quite a bit (at least a couple of pounds worth or force to move the feeler gauge) for a good adjustment. Use a go/no-go technique. Tappets are properly gapped when you can fit the correct feeler gauge into the gap, but not the next biggest size.
I do mine by feel these days. Intake are adjusted properly when you can jiggle them up and down and hear the clicking, but not feel the movement. Exhaust you can feel move just the slightest little bit.
Redliner said:
According to the shop manual, you adjust one, rotate 360º, then adjust the other.
So it would be advisable that he find which one is on compression, align the T mark, then adjust those valves. Then rotate 360º and adjust the other valves.
Simple, really.
The way that he described it, adjusting both at the same time on the T mark, makes it sound like the adjusted the tappets on one cylinder while they were opening a valve!!!
Correct.
