Rich Ard said:They used to, but not nearly as often now - cars with catalytic converters only put out a very small amount of CO2, and much more CO.
johnson_steve said:Ok guys i'm no expert welder and far from a safety nazi, but i've welded on a few tanks and never done anything more then drain the tank and let it air out upsidedown overnight. Between motorcycles and my gunsmithing hobby i spend enough time trying to make things go 'boom' to know it's not that easy. Just because you have a flammable substance doesn't mean you get an explosion, you need pressure. I've dumped a half pound of gunpowder out i on the driveway and tossed matches at it, without being compressed into a sealed space to create presure it won't go boom; it fizles, pops, flashes, and smokes and you get a blackspot on the driveway. I always weld outside and wear eye protection, as long as you don't leave the gas cap on there's no pressure you might get a little flaming belch out the gas cap hole, but it's not going to fuck up the tank or send schrapnel flying about.
I did see the lower pic and was just commenting on the fatbob tanks as not a good example for what you are doing. The hummer tank is the way to do it and the way I showed in my diagram. As mentioned gas does not explode, the fumes do. You can actually weld on a tank that is FULL of gas without much concern. It's the empty ones that are dangerous. When I powder coat a tank I will flush it out and then put it in the oven to dry it out, people thought I was crazy and was going to blow up my oven. The slow rise in heat will evaporate any fumes before ever reaching ignition temp and there is no compression to worry about.o1marc said:Run a hose from your car exhaust into the tank for about 15 minutes the CO2 will kill any flammable fumes.
SONICJK said:There is in fact pressure.
When gas fumes ignites in the confined space of the tank, the combustion and expansion from heating lead to a higher volume of gasses in the tank, which will then try and escape out the fill cap, but that hole isn't big enough to allow the gas to escape effectively which will cause a build up of pressure in the tank and could possibly blow the tank apart. At the very least you get a jet flame out the filler cap (per junior haha) and the tanks is going to want to fly.
http://www.cdph.ca.gov/programs/ohb-face/Documents/explodfueltank.pdf
Personally, since I dont have access to argon regularly, I fill anything explosive with water and then drain the water. Filling the container as opposed to just rinsing it out forces everything lighter than water (gas vapor) out the filler cap as you fill it.
But your welder dude should know all this, just figured I'd add to the discussion 8)
o1marc said:The fumes will not ignite when put in a cold oven and ramped up to 400* in 20 minutes with the cap off. It takes more than that heat to ignite it. it needs an ignition source.
