Custom tank idea: Will it work?
They used to, but not nearly as often now - cars with catalytic converters only put out a very small amount of CO2, and much more CO.
Glad to have an expert on it, lol.
On a different note. Yesterday, I went to the local college to talk to one of my buddies that works there (about something other than the bike). He just happens to teach welding and told me that it sounded like fun so he'd help me out. He said the best way to do the job on the tank would be with a TIG welder. He says its a real precision instrument, and he uses it for alloys, stainless and other stuff like that. Its precise enough to weld 2 coke cans together without any blowouts (Which he demonstrated for me... lol.) So all I have left to do is go and get some steel tubing.
Ok guys i'm no expert welder and far from a safety nazi, but i've welded on a few tanks and never done anything more then drain the tank and let it air out upsidedown overnight. Between motorcycles and my gunsmithing hobby i spend enough time trying to make things go 'boom' to know it's not that easy. Just because you have a flammable substance doesn't mean you get an explosion, you need pressure. I've dumped a half pound of gunpowder out i on the driveway and tossed matches at it, without being compressed into a sealed space to create presure it won't go boom; it fizles, pops, flashes, and smokes and you get a blackspot on the driveway. I always weld outside and wear eye protection, as long as you don't leave the gas cap on there's no pressure you might get a little flaming belch out the gas cap hole, but it's not going to fuck up the tank or send schrapnel flying about.
Yeah, he told me to just fill it with soapy water and leave it overnight, I was just playing devils advocate. ;)
That depends entirely on the substance that you're igniting. Gasoline fumes 'explode' when they are ignited - welding a gas tank requires that you remove oxygen from the equation as much as is possible.
Gasoline fumes 'explode' in the sense that they rapidly burn and expand, but without something pushing back against the expanding gases you never build up any pressure, which is what i think of as an explosion vs a flaming fart. If the flame front can expand without limit you never get anything much higher then atmospheric pressure and it quickly exhausts it's fuel and puts itself out. I'm not arguing against taking safety precautions or advocating anyone to do any of the stupid, dangerous shit i do. I'm just saying that in an open environment (vented to atmosphere) gasoline will never develop the pressure or temperature that it can in an engine just like how my pile of black powder went off like a glorified sparkler instead of a roadside bomb; it didn't even get hot enough to crack the driveway.
Actually if there is a small amount in it and you light it at the fill hole it wii shoot a jetlike flame bout 3' in the air. Don't ask me how I know that,lol.
o1marc said:
Run a hose from your car exhaust into the tank for about 15 minutes the CO2 will kill any flammable fumes.
I did see the lower pic and was just commenting on the fatbob tanks as not a good example for what you are doing. The hummer tank is the way to do it and the way I showed in my diagram. As mentioned gas does not explode, the fumes do. You can actually weld on a tank that is FULL of gas without much concern. It's the empty ones that are dangerous. When I powder coat a tank I will flush it out and then put it in the oven to dry it out, people thought I was crazy and was going to blow up my oven. The slow rise in heat will evaporate any fumes before ever reaching ignition temp and there is no compression to worry about.
I got the measurements for the gauge from the guys at some city cycles. The inside diameter on the pipe/tube needs to be between 61-66mm. I've had no luck finding any. Any ideas?
Find somebody with a set of rolls and have them roll you a cylinder of the diameter you want and from the sheet metal guage that suits your tank metal thickness the best.. One more bead to weld but you're welding the tube into the tank anyway.
Keep at it - a neat mod.
Pat
There is in fact pressure.
When gas fumes ignites in the confined space of the tank, the combustion and expansion from heating lead to a higher volume of gasses in the tank, which will then try and escape out the fill cap, but that hole isn't big enough to allow the gas to escape effectively which will cause a build up of pressure in the tank and could possibly blow the tank apart. At the very least you get a jet flame out the filler cap (per junior haha) and the tanks is going to want to fly.
http://www.cdph.ca.gov/programs/ohb-face/Documents/explodfueltank.pdf
Personally, since I dont have access to argon regularly, I fill anything explosive with water and then drain the water. Filling the container as opposed to just rinsing it out forces everything lighter than water (gas vapor) out the filler cap as you fill it.
But your welder dude should know all this, just figured I'd add to the discussion 8)
The fumes will not ignite when put in a cold oven and ramped up to 400* in 20 minutes with the cap off. It takes more than that heat to ignite it. it needs an ignition source.
Lamb, 64mm is 2.52", 61mm is just under 2.5", should be easy to find that size tubing at a muffler shop. Or they can take a 2" tube and swedge it open to the size you need.
That's completely different than welding a tank.
Autoignition of gas fumes happens around 550F when conditions are right.
Mig welds are over 2000 degrees.
I'm not saying its gonna blow every time. In fact most times it won't, but that one time when the conditions are just right, you'll wish you had taken the time to properly empty the tank.
i just double checked the math on google,... I don't know why but for some reason I derped out there for a while when I was looking for the stuff earlier. I'll just order some online, shouldn't be very much. Thanks for running the numbers again.
it sounds like you are improving on a classic Harely look. Either way, it sounds like a super cool idea. I wonder if you could just mount it into the tank and have like a 1/4 SS tubing threaded into the bottom meeting the back on the guage. This could be caulked on or whatever adhesive that would be resistant to the gas. Can't wait to see it.
http://www.hotbikeweb.com/features/0705_hbkp_2006_kustom_culture_sailing_hogs/photo_02.html
good luck with your tank,cool design
just wanted to through this in there if it hasn't been mentioned but dry ice works perfect, throw a few chunks in before welding, as it boils off co2 at a steady rate it safeties up the welding process nicely
used to be able to get dry ice at safeway and some likker stores
Im telling you it will blow up ive spot welded on tanks full pf water and they balloon up like crazy and spray water through weakest point dont fuck around unless you know
