SrgtBear
The arsenic has oddly shaped feet...
79 KZ650 4-Cylinders Dry and Wet Test
-1- -2- -3- -4-
100 135 110 125 - Dry (PSI)
150 145 150 165 - Wet (PSI)
I'm looking for input. Based in my assumptions and what I've read in the service manual the piston rings needs to be replaced. Valve clearances have measured and they are all within spec. The bike runs but it has symptoms which sound like air pressure is escaping or possibly being exchanged from one cylinder to another through a bad gasket between cylinders. It sounds like a back pressure hiss and pop up near the front left cylinder #1. In gear the bike jump around around at 2-3k with hiss and pops but runs fine throttle open. In neutral it will mostly rev smoothly.
Anyone experience this before?
-1- -2- -3- -4-
