Decipher Compression Test Results
SrgtBear
The arsenic has oddly shaped feet...
79 KZ650 4-Cylinders Dry and Wet Test
-1- -2- -3- -4-
100 135 110 125 - Dry (PSI)
150 145 150 165 - Wet (PSI)
I'm looking for input. Based in my assumptions and what I've read in the service manual the piston rings needs to be replaced. Valve clearances have measured and they are all within spec. The bike runs but it has symptoms which sound like air pressure is escaping or possibly being exchanged from one cylinder to another through a bad gasket between cylinders. It sounds like a back pressure hiss and pop up near the front left cylinder #1. In gear the bike jump around around at 2-3k with hiss and pops but runs fine throttle open. In neutral it will mostly rev smoothly.
Anyone experience this before?
Has the bike been sitting for a long time? Could be the rings are gummed up and might need a period of running to free them back up......or they could just be worn out.
Could the hissing / popping be a leaking exhaust gasket? If it was the head gasket leaking you wouldn't expect to see such a large increase in compression with the addition of some oil.
An exhaustive leak-down test could pinpoint the cause of the problem, including leaks between cylinders.
The bike has been driven and ridden hard around the neighborhood. It definitely hasn't gotten any better. With that said the his and pop is irregular and at sporadic moments when the engine is under load. This doesn't leave me to believe it to be an exhaust gasket because a leaky exhaust gasket wouldn't effect the engine at much at all.
It's most likely a leaky gasket or worn piston rings. Bike has been sitting for about 10 years.
How might someone begin and conduct an extensive leakdown test?
You position each piston at TDC on the firing stroke and shoot compressed air into the spark plug hole. Air will leak out of the crankcase breather if the rings are worn, through the inlet port if the inlet valve is defective, or through the exhaust if the exhaust valve is defective.
The trick is holding the crank still while you are doing this.
And remove the plugs from the cylinders on either side to see if air leaks out there to confirm gasket is blown between holes.
You can build a tester. Plans are out on the web. Basically, you need a regulated air pressure of 100psi and a gauge to measure it after pressurizing the cylinder. 90 psi is a 10% leak.
There's some good input already but doesn't necessarily give you a road map to follow.
The increase from dry to wet tells us two things. First: the rings are not sealing very well. And second: that the amount of oil added to each cylinder was different. More oil=high compression reading. That's probably why teh wet readings are inconsistent from one cylinder to another.
Fist question is what make of compression tester did you use? If it was a cheap HF, try to get a better one and re-test. If it was a good one, the motor is in need of a freshen up and the top half has to come off.
You can do a leakdown test for sure, but a cheaper and faster test is to take a compression test adapter tube, screw it into a plug hole, connect up a compressor/air tank and listen for leaks. Knowing that you have 5% or 15% leakdown is nice to know but it doesn't tell you what the problem is or where it is.
If teh rings are stuck they can possibly be freed but not running the bike is not guaranteed to help any. The best plan at this stage is to strip the top end off and check the barrels, pistons and rings and repair/replace whatever is worn/stuck, broken.
That is a leakdown test.
OK smart arse :-) I mean that's the quick and dirty and perfect for this situation. On race motors we do a leakdown test with a tester to determine the degree of leakage. 2% is OK, 5% is not and the motor has to come apart.
For this situation I agree that all we need is to listen for a huge assed hissing sound
At 100PSI all engines will leak some air. If the leak is bad you will hear it very easily.
Yeah, good idea on the quick and dirty. I have QD's on all my compression adapters. So, it will be easy enough.
