Easiest way is use longer shocks, but what you have there looks pretty close. Best way to check your clearance is to remove the spring off the shock, then mount it up and pull the swingarm / wheel up to mimic full shock travel. If it clears, then you're OK.
If you go with longer shocks, you 'd want to check your chain doesn't touch the top of the swingarm pivot (you're effectively lowering the chain line). If that happens, you can get around that to some degree by using larger sprockets front and rear (IE 1 tooth up on the front and 3 teeth up on the rear will get you a similar ratio to what you have now)
