crazypj said:If you have a welder, you could put a 17mm nut over the broken stud hole and fill it up with weld.
Quite often works
Don't even THINK about an Easy-Out
neevo said:No probs PJ. Will straighten the 2 ones left and hit it with the heat and anti seaze over a few days and then try the double but thing again.
This bike is a nightmare! Everything that could be a pain is. Oh well.
crazypj said:Put wheel in and check chain line, Rocan had an issue with his 350 and had to cut a chunk out of brace
400f never had single cable, I would use it though![]()
neevo said:Will do Staffy, saw that Inox at Bunnings and thought it was just a WD40 alternative. The "pen-o"doesn't seem to be working anyway even with heat and hammer blows.
If that doesn't work I will take it to somewhere to get it done properly.
