DTT Barber Build 2012
I was going to leave the wheels the way they were. I just need to replace the front rim that is bent. 19" 40 spoke rim.
I finished removing everything that I could by myself. Should get it fully disassembled this weekend.
I was taking a look at the stock toolbox and I think that would be a great place to put an electronics box since there won't be any room under the seat. From the left side it will be hidden behind the exhaust. I already have a small AGM battery that was under my seat hump so I am going to start working on a design for the box. The only other electrics I have are the regulator, rectifier and starter relay. Some of that could be put under the seat.
Also just finished the design for the front turn signals. I think it is just a cool small detail. It will be a surprise for Barber.
Hey FLug that rectifier/regulator thing that guy found over on Twins is pretty awesome and pretty small. It is about the same footprint of the regulator but thiner and you only need it and not the rectifier. I built one into my 450, removed all the excess wiring as well. Pretty simple, especially if you have done the radio shack rectifier mod. Its just plug and play then.
Looks like this, just have to plug it in and fab mounts for it... Silly cheap too.
http://www.ebay.com/itm/Voltage-Regulator-for-Kohler-Replaces-25-755-03S-25-403-03-S-4140310S-/180851135988?pt=LH_DefaultDomain_0&hash=item2a1b9155f4
Yeah man, I was actually researching that today. Didn't quite understand how it would wire in to the system since there are only three prongs. I guess the case gets grounded? I was going to go back and take a look at the hondatwins thread but my tapatalk is being flaky. I figured I could just mount that to the bottom of the battery box I design.
I have already done the rectifier mod, but a lot of the wiring is probably going to get redone since I'm moving stuff all over the place.
Hmmm, it looks like it is hondatwins that is down.
If you have done the rectifier mod then you just unplug it, plug the pink and yellow into the wavy line prongs the red into the + and the green just change to a hole terminal and stick it under one of the bolts that holds the unit down. Then get rid of the old regular wiring since it is just spliced into the harness anyway.
Here's a pic or two of what mine turned out like.
Twins is down right now has been most of the day, server outage or equipment malfunction.
Yes, I think so. I was actually going to post a pic of mine and ask of it could just be bent back into shape.
I'm very leery of salvaging rims. Any bends are gonna be hard to true, and potential failure points if you hit a good bump.
Flug, I do have an ugly but solid wheel truing fixture to offer for lacing that wheel if you want. Its actually using a dial indicator instead of a rod so its a tad different..
Fix, I understand. That's why I was going to ask for opinions.
E, What? My ghetto rig with the "screw indicator" isn't good enough? :)
Sorry, I didn't see this post before I replied to your PM.
Looks good to me, though I can't tell the size or # of spokes from the pics.
It will get painted black so I'm not too worried about the finish.
DTT Barber Build 2012 -The CLobber
Meet the CLobber.
I had some time to draw at the GTG while everyone was riding. I think this is the general idea though some of it might change a bit depending on what is available. When the guys got back from the ride they thought it was funny I had CL pipes on a bobber, so they called it the CLobber. :)
trek97 said:
you pert near got a bike. and the drawing is awesome.
Thanks. Though a lot of that picture is traced from one of the photos. I'm not that good of an artist.
Does anyone know if the early cb750 and the early cb750f supersport frames are similar underneath the tanks? I was trying to figure out if a cb750 tank would fit. I know a cb750f tank does not.
Re: Re: DTT Barber Build 2012
They are identical frames mike. Prolly a no go if the f doesn't fit.
Sent from my DROID RAZR using Tapatalk 2
