DTT Barber Build 2012
It can be done, just not easily.o have a donor frame here as we speak, and am possibly picking up a roached 500t in the morning. We can figure something out. Good possibility it can be fixed, it's just a matter of how tweaked it actually its.
Sent from my DROID RAZR using Tapatalk 2
To be honest guys, it really isn't that bad. In fact, I would feel comfortable riding it like it is. I wouldn't go racing it, but casual riding would be OK. The only place it is tweaked is between the two main engine mounts. The mounts are OK and the bolts came out fine so the mounts themselves are not tweaked.
What I am worried about is it cracking over time. That is why I was looking to repair it. The idea is to take that joining piece and extend it out over the crushed part of the frame.
VonYinzer said:
Ok, I want to publicly apologize for not getting you the gas tank and pegs yet. I PROMISE that Ill get them out to you asap!
Sorry... :(
No worries man, this heap ain't goin nowhere.
If the bolts came out with no more effort then normal I would bet you haven't messed much up. I know the bolts on mine are not hammer and punch tight but they are pretty damn close to it. I would worry if it required a ton of force to get things loose. I would still get it up on a table, level it out as best you can and measure every direction you can think of.
ONE thought could be to drill out the spot welds on the Y shaped unit bracket on the front and then cut that rail off right next to the bottom bolt hole. Then cut the same piece out of a donor frame and then weld it into place with a slug in end next to the bolt. Then weld it up, seams and all.
Tim said:
I'd almost think it would be best to get a donor frame, stamp the VIN from the damaged one onto the new frame and scrap that one.
Just for future reference... that is highly illegal. Proceed at your own risk ;)
So I am still making progress on this......slowly. Got some more parts cleaned and wrapped up for transport. I am starting to work on the wheels.
First, I can't figure out how to get the old tires off so I can disassemble the wheels.
Second, I think I am going to get some new tires. I didn't like my old ones. They are both cheng shins which I understand is chinese for cheap shit. They are crap. I didn't trust them in the corners and they weren't even round. So, I am looking for recommendations. I kind of wanted some chunky tires to go with the scrambler exhaust, and I like the look of them. However, I don't ride on trails and don't really plan to (except for Kiley's driveway). So I am not going to get tires just for the way they look. I want them to perform well for the riding I will be doing. Cruising around town and up to the mountains. I'm trying to stay under $150 for both tires.
Thanks.
I got some dunlop k70's front and rear for my bike, they have that old style look to them but they are made with newer style materials. I put the back tire on my 360 since I wore out the IRC I had and so far I really like it. Corners well, looks old school and is supposed to last more than the 2000 miles I got out of the IRC.
http://motorcycle.motorcycle-superstore.com/search#w=dunlop+k70
Rich, I will have to look at the sizes when I get home but the front is 19" and the rear is 18".
The owners manual says 3.25-19 and 3.50-18.
Any problems running tubeless tires with tubes on old rims?
If they are stock wheels, then probably 1.6" front, 1.85" rear. I have a 1.85" by 19" front hoop you can have for free (stock Suzuki wheel). And there are no problems running tubeless tires with inner tubes.
I ran Kenda K761's for a little while (out of necessity) on my GR and had no problems. I know a lot of folks have ran their other tires and liked them.
Hit up Beatnic he can get you a deal on Shinkos and I just put 3000 miles on the set e sold me and they were excellent. 90 + mph on hte freeway, through buckets of rain at the same speed, scraping pegs through S curve ramps and never once felt scared or like I was going to loose grip. He has sold sets to a few othe members and so far everybody is happy and they are more than likely in your budget.
Cheers
Maritime
Sorry Flug, I just realized - you would need 40 spoke rims, correct? All I have is 36 spoke hoops.........
Rich, I've sourced a new front hoop from Travis. But yes, it is a 40 spoke. I was really just looking for tire recommendations or info like Mike just sent. Also if you guys know how to get these tires off without any special tools that would be great.
So for it looks like I will be getting the bridgestones or the shinkos if I want to stay in that price range.
A set of motion pro aluminum tire irons would set you back about 20 bucks and 3rd would be better. I use 2 and a big screw driver. Worth the $$ for sure. For the old tires, you can cut em off if you want but spoons and tire lube will make it easy and not damage the rims. There is a good youtube how to I watched and I removed the old and mounted and balanced my new tires, with tubes on the GL. Wasn't too bad at all, small bites and patience and you will be good to go.
I've got tie tools galore here if you don't get them swapped before hand.
Mad science bitches!
Just trying to get as much done ahead of time so there is less stuff that NEEDS to get done at Barber.
I think the problem is that it is as hot as a fat man's taint in my garage and I'm dripping with sweat after trying for about 5 minutes. Frustrating.
HAHAHAAA, shoulda seen me trying to get the 20 year old tires off my 450, took 2 HOURS in my A/Ced garage and I was still sweating like a pig. I should have just cut them off.
BTW, hit up the junk shops this winter, can buy window A/C units on the cheap, I'm glad I did now. 110 in the shade at 4:00pm every day makes for shitty work in the summer without one.
If you don't care about the tires. Cut them off with an angle grinder.
Cut through the majority of the tire with the grinder, and cut the bead with a pair of tin snips.
I only lost about 5 lbs of sweat but I got the tires off. Of course now I can't find my spoke wrench. It never ends.
I looked on the spreadsheet on the Google doc, do you still need a shifter and bucket? I have a spare shifter and bucket from a 350f I wont need.. In fact I have bunch of parts for a 350f, if anything fits the 450.. Just thought I would help. Going to Barbers too, so I can bring tools there if need me. But I can ship whatever I have before then..
Also, is a petcock still in need?
