Hey guys... I need you expertise again... as usual.
I am working out my controls, switches, etc... for my handlebars on my CB450 and I have a couple of questions...
I want to re-locate the switches that usually reside on the right handle bar... the Off/on/off engine switch, the start switch, and the off/low/high beam switches. I am going to use a new headlight that has the toggle switch for it built in so that switch is a non-issue.
Question 1. Can I use any toggle switch for the engine run stop switch? I would like to run a little chrome "bat" style toggle that is just on/off for run/stop... can I do this? Do I need a separate "kill" switch or will switching the switch to off effectively kill the motor?
Sorry if any of these sound like dumb-ass questions... I got my bike not running so I'm not even sure how the stock switches even functioned.
Question 2. What rating do I need to have on that switch? Volts. Amps. Etc...
Question 3. I would like to use an Off/Momentary On switch that matches the other switch for the starter switch... what ratings would I need on that switch?
EDIT: This site has 20amp sealed toggles in both the ON/OFF, and OFF/MOM ON configuration... would these work okay?
http://www.wiringproducts.com/index1.html
I am planning to make an aluminum plate to mount the switches and then mounting them somewhere on the triple-tree.
Thanks for your help.
-Woody
-Woody
