Electrical / Switch questions
woody1981
Coast to Coast
DTT BOTM WINNER
Hey guys... I need you expertise again... as usual.
I am working out my controls, switches, etc... for my handlebars on my CB450 and I have a couple of questions...
I want to re-locate the switches that usually reside on the right handle bar... the Off/on/off engine switch, the start switch, and the off/low/high beam switches. I am going to use a new headlight that has the toggle switch for it built in so that switch is a non-issue.
Question 1. Can I use any toggle switch for the engine run stop switch? I would like to run a little chrome "bat" style toggle that is just on/off for run/stop... can I do this? Do I need a separate "kill" switch or will switching the switch to off effectively kill the motor?
Sorry if any of these sound like dumb-ass questions... I got my bike not running so I'm not even sure how the stock switches even functioned.
Question 2. What rating do I need to have on that switch? Volts. Amps. Etc...
Question 3. I would like to use an Off/Momentary On switch that matches the other switch for the starter switch... what ratings would I need on that switch?
EDIT: This site has 20amp sealed toggles in both the ON/OFF, and OFF/MOM ON configuration... would these work okay?
http://www.wiringproducts.com/index1.html
I am planning to make an aluminum plate to mount the switches and then mounting them somewhere on the triple-tree.
Thanks for your help.
-Woody
Woody, them should do ya alright. 20A is more than you'll need. The voltage is pretty much a non issue with most automotive applications as it's only 12VDC and a lot of switches are rated for 120VAC, though, it never hurts to be sure.
The red switch lever on top of your right control is the kill switch. It's wired to the ignition coils so when you switch it to off the spark is interrupted and the engine dies. Should it be okay to replace the kill switch with a toggle. Solder the black and white wire to the positive lead in the toggle switch and negative (black) to negative lead on switch.
The main fuse is 15 amp so anything above that is fine.
Same as kill switch.
Yeah, those switches look like they'll work.
