Electrical upgrades- CB guys, what are you running?
Don't want to jack the thread, but wtf?
It looks cool and is lots-o-work, but EFI and such are for power-improvements right? adding some extra flywheel is not?
How are you going to keep the oil inside anyways?
Well... keeping the weight down was a requirement and that's why the rotors were cut and turned. After all the metal was removed, I'm up less than 40% on the weight of the rotors as compared to two stock ones.
As for keeping the oil inside, I'm using this:
I had a machinist friend turn me out a very large spacer.
HAHAHA YES! i was hoping for that picture! nice job on the weightloss btw!
I did similar hop-up on a cb550, but found out it was very hard to keep the outer ring center due to the strong magnets. Are those PU spacers between the alternators enough to keep it steady?
It's a pretty snug fit inside the spacer, so I'm counting on that to do most of the work, but we'll find out. ;)
Not really, everything is spinning concentrically; the forces should be all fairly balanced.
I went with a full system overhaul including:
1. Total rewire
2. LED rear light
3. LED turn signals
4. Acewell gauge (to be purchased)
5. Multiple fuses
6. Combined reg/reg (to be purchased)
7. Relays for running coils, headlight
8. New starter solenoid
