quadracer351
Coast to Coast
Re: Re: Engine inspiration thread!
Yeah I knew it wouldn't cure from engine heat but I have a heat gun that reaches 1375F that I was going to go through the heat cycles with. I also choose the vht flameproof because the red they had plus the clear gave it just about the same red as my frame. I'll try looking more for a closer red in the engine enamel. I only used engine cleaner, brake cleaner, and a rifle bore cleaner brush along with the red scotch brite pads.
Sent from my SCH-I535 using Tapatalk 2
JRK5892 said:quad do not use 1200 on these motors it simply does not get hot enough in operation to cure the paint to a final cure and it will always be very very fragile and will chip like mad, use the 500* use a very light coat of primer, and then base coat it, i do not typically like to use the clear high temps as they just tend to flake, bleach, and chip... i did a full write up a while back on painting a motor if you want to search my name and that. let me know if i can help.... i like to use an engine cleaner, then non clorine brake cleaner to clean up the motors for paint, super easy and really works great
