ShadowPlay
So I have been lurking this forum for a while since i have been working on my first build, a 1975 cb360. I know there has been many threads made about the clutch on this bike but I just cannot seem to get it to work properly and I was hoping i could get some help on here.
So I started off with the classic popping clutch issue, i got the cover off and replaced the cable only to find that it still pops, after reading more i found out that my cable could be too short so i removed the spacer from the adjuster in the lever. I then proceeded to try every combination of removing spacers, I took out the one at the lever and the casing, then just each one individually, and both in. This ended up solving the popping issue but now the clutch will not fully disengage, i can move the rear wheel with my hands but there is still a lot of resistance and about 1/2 inch of cable slack before the lever really seems to start doing anything. before anyone asks, yes i do have the ball bearing.. Any help that i can get would be greatly appreciated, thanks in advance!
