so that was your crazy idea?crazypj said:Looks like a cut down GSXR/GSXF head, (SACS motor) lower hole in side is for rocker arm pivot
After looking at pics, I think Icould modify some of the 'mistakes' I made when cutting starter plugs to hold a Kawasaki EGR reed block?
Texasstar said:so that was your crazy idea?
not yet I found a Suzuki DOHC head on a cb77 bottom... Thanks I will look that up! Is koositra Dutch?teazer said:Giannini's CB77 based F250 motors. 2 valve per cylinder top ends like a GS500, so no rocker arms but only single inlet and exhaust per side. Have you found the CB450 top end on a CB77 bottom end that Pete Rhodes created a decade or two ago?
Fastest CB72/77 based motors are still those created by Jerry Koositra in South Oz.
For an 8 valve 200 motor a 200/250 top end or 4 cylinder 400 might work if it had enough fin area. Or weld a head or cast a new one. There are options - just above my pay scale though
Maybe find a CR93 top end and graft that on. They flew as 182cc motors and could probably be stretched out to 200cc.
bingo GS 400 http://home.comcast.net/%7Eeholman/repspec.htmlcrazypj said:Maybe a SuzukiGS550 four head or Kawasaki KZ500/550 could be easier to modify?
GS500 is 74 mm bore so would be way too big for a 200 twin (they are below 50mm?)
Just had a thought, what about a VF400/500 head?![]()
sorry just read the bottom sentence we have been looking for a vfr400 head at Teazers suggestion. It takes care of the cam chain issue with a similar gear to the rc166. Found a rear one on ebay a while back... That is on the burner but we need to learn more before we jump in that water. Teazer nailed the pic I posted it was from Giannini's facebook. That string I posted on the cr72 mentioned the mate that built the cb450 head on the cb77 bottom. All I know is all of these "mates" give me hope for humanity.crazypj said:Maybe a SuzukiGS550 four head or Kawasaki KZ500/550 could be easier to modify?
Thank you Crazypj!crazypj said:Lead hammer and V-blocks or centers, (yep, you get to do some 'precision beating' ;D )
You can also use a bronze hammer but they tend to be lighter
I do my XS650 cranks in the lower case running on center bearings only. It works but you have to think about which way DTI is moving compared to if it was on centers
I don't have any problems with the HF DTI, the contact tips need to be tightened up plus they may be 4x48 tpi or 2.5x0.45mm thread,
I had to buy both dies to make extension rods. It kinda sucked the thread varied
crazypj first to all to all that have paved our way let me say forgive us...We are to the part of our build where we are learning about exhaust systems. We are also following our credo.."I wonder what what happen if?" Now we know we aren't suppose to run assymetrical exhaust but when we did we broke ninety with our little lucky and that was without megaphones and my big arse on her with a cam that only has .157" lift! Yes carb tuning is a nightmare but really it is two engines sharing a crankshaft? Now if it takes both torque and hp to get to speed at bonneville we will have to make a compromise or will we? What if one helps the other? I learned this from being married for 25 years one is push and one is pullcrazypj said:Do you have tabs and stays on megga's?
They will never stay in place just clamped to pipe
Pipes look 'wrong'
It looks like you have the right pipe way too long compared to left?
Texasstar said:crazypj first to all to all that have paved our way let me say forgive us...We are to the part of our build where we are learning about exhaust systems. We are also following our credo.."I wonder what what happen if?" Now we know we aren't suppose to run assymetrical exhaust but when we did we broke ninety with our little lucky and that was without megaphones and my big arse on her with a cam that only has .157" lift! Yes carb tuning is a nightmare but really it is two engines sharing a crankshaft? Now if it takes both torque and hp to get to speed at bonneville we will have to make a compromise or will we? What if one helps the other? I learned this from being married for 25 years one is push and one is pullbut some how it works. No tabs and stays on the megaphone but we went to the hardware store and picked up some washers and springs...thanks and Lucky's front end has never lifted until now
can't wait to go to the dyno! My wife has told me if I try to share my crankshaft she will throw a rod.
