Father Son 75 CB200T Rise From the Ruins
Is the indent wheel off center?
Check the webbing in that 500 hub theyre notorious for stress cracks
Youre going to need to swap the tripples on lucky for something wider and still lathe the hub and plate narrower
Post what 1.6 hoop you use as ive got a 500t hub that needs the same
Ps whats the collective noun for 9 brittens?
Si. Wheel is off center!
Yep another fork swap :(
Will check the web!
We used the 1.6 X 18 on Victoria with the cb450/77 brake
Eargasm!
Ps sunroom smells like race fuel.
Eargasm!
deviant said:
OH YEAH!? This I have to look up.
I don't remember if it used a custom block or if they converted RM125 cylinders
It was water cooled and I believe used the oil pump drive for waterpump?
Are you talking Barton triple from back in the day or Sparton if it was in a Spondon frame? That was neat motor with individual combustion chambers in a common water jacket - three decades before that became common and trendy in 125 racing circles. Don't remember 115HP though - more like half that as I recall.
http://yorkshireferret.blogspot.com/2012/02/barton-motors-sparton-phoenix-and-more.html
http://www.ozebook.com/compendium/suzipics/sparton.html
But yes a 380 can be transformed into a very potent little bike.
teazer will these engine produce 20 ftlbs torque?
Texasstar said:
teazer will these 175 engines produce 20 ftlbs torque? Sorry I meant to say the our cb175 engines.
Texasstar said:
we are 3.38mm taller than the quench of the 200 piston
bump from page 148 well we know a little more than we did back then! We decked .120" to care of our compression problem. While we are at it lets take care of our cam chain problem in this engine build. Shall we rephase while we are at it? We have the slipper chain tensioner, the Yamaha rods, the 57 mm Tbolt pistons with the 13mm.
teazer said:
What are the rod dimensions? And is that a potential 200 replacement rod or 160-175?
yes for a 200 engine and I will measure the rods tonight. Boring out a 175 to 57mm cost a pretty penny however we will lose being able to drop 600 grams off the rotational mass because of the single clutch gear. Now the goal is to rephase to 76 degree crank to test Phil Irvings theory. Build the 200 as close to what we did with Victoria.
There is an excellent PDF embedded in this string "An article that might be of interest to technical/historical-minded Scrambler owners appears in the April 1994 issue of the British magazine Classic Bike. It is titled: More Torque, Less Vibration. It documents how Dick Cookson converted his Triumph twin Metisse scrambler to a 76-degree (or 284-degree) crank from the factory 360-degree crank, based on a theory by Phil Irving (who of course designed the 1000 cc. 50-degree V-twin Vincent motorcycle). Its an interesting article, documenting Phil Irving's theory and explaining relatively clearly the differences between a 360 degree crank and a 180 degree crank, the benefits of a staggered 76-degree (or 284-degree) crank and comparing it to the only slightly different 90-degree (270 degree) crank as we now have in in the current Triumph Scrambler." http://www.triumphrat.net/twins-technical-talk/281450-phil-irving-and-the-270-degree-scrambler-crank.html#/forumsite/20545/topics/281450?page=1
Click on the no image in the first post and it will take you to the pdf. :)
simo said:
This should be fun, Whats your slipper from
simo is this you http://www.cnczone.com/forums/i-c-engines/3549-make-cam-grinder.html
