thanks Q!Q said:pg 7 thru 12
http://www.tioc.org/1993-3PM7.pdf
Oh well thought I would ask!simo said:Sorry thats another Simo
Megacycle will do the lobes moving for 40 bucks a lobe. But would like to do a mock up cam. Need a crank truing jig also.simo said:Are you planning on building your own cam? I liked the idea of having the lobes independant of the shaft, then locking them in position, need a fair bit of work to make fit / and channel oil
He didn't actually use it.Texasstar said:What do y'all think of this crank truing jig? http://youtu.be/jawQjIEvj1Y
cmon duchat it can double for spoke truing....most of my machinist friends cringe at this lolDuchat said:He didn't actually use it.
I haven't done any machining and don't know how to true a crank so I kept waiting for him to demonstrate. I've trued some spoke wheels though and yes it would be great for that. He said he spent $1000 AUS? Better be doing it more than once.Texasstar said:cmon duchat it can double for spoke truing....most of my machinist friends cringe at this lol
https://youtu.be/H0Uas7leQggDuchat said:I haven't done any machining and don't know how to true a crank so I kept waiting for him to demonstrate. I've trued some spoke wheels though and yes it would be great for that. He said he spent $1000 AUS? Better be doing it more than once.
thanks Crazypj how familiar are you with Harley/Aermacchi sprints?crazypj said:I used V-blocks on a surface plate for years then I realised you don't need that much. As long as you can have crank turn on some pieces that don't move and can mount DTI's just about anything can be made to work for truing although wood has a bit too much flex. You may have to work out which way things are going to move depending on how they are mounted though. For XS 650's I use the crankcase with a plate bolted on (for magnetic bases) and leave off the outer main bearings.
Twins are only slightly more difficult than singles.
As for re-phase, you may need slightly different angles because of con rod length. (I may not understand the math invoplved but I fully understand the concept and reasoning.) Kop and I have been going back and fore through it a bunch of times. It was all to do with removing weight from crankshaft due to piston position (one at max acceleration, the other at TDC or BDC) The change in balance and reduction in vibration was a happy benefit (I must have read a different interview with Phil Irvin about the 76 degree Triumph?)
With the XS650 I think 79 or 81 degrees were optimal (I forget, it was at least 7~9 yrs ago)
The article that keeps getting posted is mainly about less vibration but initially it was a 'race only' mod for crank acceleration and therefore vehicle acceleration/ lower lap times
well we were back on Lucky this weekend.. .we have looked at the Suzuki before price was a concern. However we will take a closer look who knows what we may stumble across. We have been riding both Lucky with stock oversize Pistons and Victoria with the 57mm Tbolt. Both are a blast! Then when you get on the Stock Cl200 you feel like you are standing still.Q said:Hi Patrick
I get confused with all your builds, but ran across a couple things that may be useful. If your still searching for a piston, visit the Wiseco site, and use their search for the following:
2013
Suzuki
DR-Z125 L
This should bring up three flavors, 57, 58 & 61 mm.
The 57 & 58 mm pistons have a dome height of +10.6cc
P/N 4815M05700 and 4815M05800 respectively
The 61 mm piston has a dome height of +9.5cc
4815M06100
These all have 14 mm piston pins
I do not know weight or heart-line dimensions or what the actual (physical) displacement of the domes are. The seem plenty high though. They are a tad pricey but can be found for less elsewhere. I am curious if you have already reviewed these.
GEARING
Have you looked into the possibility of using the 5th gears from a Honda CB125Twin (or CB125B6)? If your running out of rpm, these may help.. I do not know (for sure) if they will slide onto the CB175 main and counter shaft. Discussing with simo, we think they will or have you already looked at this? If they will work, they can provide lower gearing than the CB200 (or CB350 for that matter).
