Father Son 75 CB200T Rise From the Ruins
Sonreir said:
Also... don't mess around with the timing too much until you get some dyno time. You don't want to blow your engine. Definitely keep it less than 40° of full advance.
Zeke is having too much fun for us to blow this motor up...we have 350 miles on our new motor. There is a motorcycle dyno by my office so that is coming up. At how many miles do you recommend starting the dyno process? Michael Moore of Eurospares said on his web page that Dyno time is paramount for learning. He said his cr216 was putting out 12hp at the wheel and when they were finished with just messing with the jets, timing, and length of velocity stacks the had 20 HP at the wheel. However his motor was turning 12k and he blew it up with a rock in the carb.
http://www.eurospares.com/cr216.htm
http://youtu.be/Ikc2alx29rE
My opinion is that the break-in process is completed within the first hundred miles. Having taken my engine apart with just 24 miles on the clock, I can verify the cross-hatching in my cylinders is gone.
We are on the dyno and running way rich...about to rejet.
1st run 12hp
2nd run no filter 13hp
Wow went down to 90's on our jets and she is still running rich. Lucky ran up to 10k no sputtering!
15hp at the wheel!!!
How come we need smaller jets than stock?
Sonreir said:
Smaller jets than stock?
What your guys' altitude?
not yet??! Our stock jets are 88 and we put in 90's and the dyno says we are too rich. I am making a video of all the runs so you can see. I am a little baffled. Dallas elevation is 430' above sea level...unlike The Dutch being below sea level...lol
The cl 200 is suppose to have 95 jets as stock
I don't think that's it.
Less fuel required indicates that either less air is getting into the engine (not a good thing) or you're facing a bit of a reversion problem (also not good).
what is reversion?
the plugs tell a different story. The left is the bronze and the right has the tip turning white.
Difficult to make out, but I'd trust the wideband on a dyno before I trusted a plug chop.
As for reversion, it's commonly associated with high duration cams or having your cam timing off. It's when fresh fuel/air mix gets pushed back out of the intake valve by the rising piston before the intake valve has a chance to close. This results in additional fuel residing in the intake tract and causes a rich condition at lower RPMs. This will generally go away are RPMs increase.
I would probably agree with going with what a dyno says over a plug chop. If I compared my plugs with yours I would say yours are way rich. And doesn't a stock cb200 run with 17 hp? It seems like Sonreir might be right.
thanks caveman it is my understanding a stock 200 runs 10-12 at the wheel and 17 at the crank.
"Our 175 race bikes all do more that 100 em pee aitch with fairings and small rider etc. Remember that a stock motor makes about 10-11 at the rear wheel and ours make over 20 on a good day and slightly less when they are tired."-Teazer
This is how good the stock shocks are...tread pattern and some holes in our battery. So we seized the day and got a new Shorai and Lucky lost 4lbs.
Can't tell much from the plugs. Read mixture down in the bowls where the insulator meets the steel shell.
Bikes typically make most power at a richer A:F ratio than people imagine, so feel free to try small and larger main jets and see what your motor wants.
teazer said:
The HP chart looks normal for a fairly stock CB200.
Thanks Teazer. Is 15whp better than stock? We are indexing iridium plugs, thinking about running full 10w-40 synthetic, jetting down even more, trying a tank of c-12, and installing our Dyna e.i. before our next dyno run. Thoughts?
IMO,synthetic is not a good idea. It will leak out eveywhere and is not designed to cling to internals. there is also not enough zinc in it for the older motors n bearings. I'd reccomend Castrol 4T. I also agree with Teazer on the fuel.
we have 20-50 castrol 4t in it now. On our racing motor build could we change bearings etc to use synthetic? Have you knifed the cranks of your hot rods? What do you think about creating a vacuum in the motor by attaching the paver flow hose to the exhaust?
