Texasstar
Can't is a four letter dirty word
Sonreir said:How is it that the CB175 puts out more power? The CB175 has a higher redline and three more ponies?
I can't seem to find the info at the moment, but I recall that the 160s and 175s had a more aggressive cam...
I finally found the 175 cam specs I don't have the 160 specs...but will look
KO
Intake opens 10 degrees
closes 40
Exhaust open 40
closes 10
Your cb175ko has an Overlap of 20.00 degrees and has in Intake Duration of 230.00 degrees. The Exhaust Duration is 230.00 degrees. Your Lobe Separation Angle is 105.00 degrees. The Inlet Cam has an Installed Centerline of 105.00 degrees ATDC. The exhaust cam has an Installed Centerline of 105.00 degrees BTDC.
K3/K4
closes 30
Exhaust open 40
closes 10
Your cb175k3 has an Overlap of 20.00 degrees and has in Intake Duration of 220.00 degrees. The Exhaust Duration is 230.00 degrees. Your Lobe Separation Angle is 102.50 degrees. The Inlet Cam has an Installed Centerline of 100.00 degrees ATDC. The exhaust cam has an Installed Centerline of 105.00 degrees BTDC.
CB200
Intake opens 5 degrees
closes 35
Exhaust open 40
closes 5
Your cb200 has an Overlap of 10.00 degrees and has in Intake Duration of 220.00 degrees. The Exhaust Duration is 225.00 degrees. Your Lobe Separation Angle is 106.25 degrees. The Inlet Cam has an Installed Centerline of 105.00 degrees ATDC. The exhaust cam has an Installed Centerline of 107.50 degrees BTDC.
