Father Son 75 CB200T Rise From the Ruins
teazer said:
I'm not sure that is possible, but I have faith. That replaces the hydraulic (automatic) adjuster on some bikes. Not a real problem on ours but worth keeping in mind.
gotcha! we are going to use our existing bolt hole with some mods as the manual cam chain adjuster! Just got to a bigger screen to look at the fiche...all we have to do is hang the tensioner in the right spot drill a little hole and it will be "golden" thank you! Now to take care of the horrible cam rollers...
Hold off on the tensioner bolt fix until you have had a chance to work out a new blade type solution because that may require a different adjuster.
Nice work Texas. That manual adjuster looks a bit like the stock setup on my SR250. Seems to work well.
We cut the mufflers off our pipes and couldn't resist sticking our finger in the hole. We discovered the primary header is 20 inches long. It has an o.d. of 1.37" and an i.d. of 1.15...it was welded inside a secondary pipe than that has a 1.25 id and an od of 1.38. The inside of the floor of the primary is almost smooth with the floor of the secondary pipe there is a visible lip on the ceiling of the pipe.
As Kop says, Suck, Squeeze, Bang, Blow. We watched the documentary on Burt Munro again last night. "Anybody can go fast with a fast motorcycle but the challenge is to go fast with a slow one" slightly paraphrased...
We learned from our second Dyno run that good spark, iridium plugs, dyna s, dyna coil, Taylor wires, indexing plugs...increased our bang efficiency. The first picture is Jim Sabin. He is the owner of Sabin Performance where we do our dyno testing. Jim said that this is what brought us out of the rich zone. Jim also use to race a TZ250.
We are now addressing our blow inefficiency and we will work back to the carbs later as soon as we see the need to start jetting up. We are trying to keep our baseline in tact so we can learn the "why" of what is happening.
Pix 2 is of Michael Moores Cr216 road racer. You can see his exhaust follows AG Bells book to the letter. His headers are flanged coming out of the head to 1" headers 20" long and then 8" step up into a 16" megaphone. He has a 180 degree crank.
Mr. Bell says that for every .125" increase in header diameter it will push the max torque 600-800 rpms up the rev range.
Our inside diameter of our cb200 pipe is 1.15" and so this is what we will try and see for comparison.
What happens if we run open 20" headers
What happens if we sleeve the first 8" with 1" od pipe?
What happens if we insert a 1.25 " od pipe into the header and make the over all length of the exhaust 43"
What happens with 16" megaphones?
Any other cones would you like us to compare from the list?
We are also debating whether to go ahead and Serdi cut our valves and seat while we have them out...since the biggest obstruction is the valve/seat itself...however I think we will save that for another dyno info gathering run.
Hahaha, I was considering picking up that CB250 myself, but I have way too many bikes on my hands these days and funds are slow.
They have two or three other CB250's around that are mostly complete so you'll never run out of parts!
Just keep your mitts off of the green SL100 in the back. I plan to scoop her up some day and ride her to pieces.
cb175 :)
Ah! Well they still have plenty of parts there. Hell I counted seven SOHC CB750's. They got some treasure well buried :P
we are looking forward to seeing you ride little green!
teazer said:
Looking at the data, I'd suggest a slightly larger main air jet to tilt the fuel curve.
Of course they are not available from Keihin or Honda but the pressed in jets can be removed with careful work with an EZ out. Then drill it 0.2mm larger and carefully press them back in.
Or get some new ones machined up. That's what we did with Cb77 carbs on our 175.
LOL!!!!! We have a cb175 because of you two!!!!! How?
Because if you had told me the only difference between a cb200 18mm carb and a 20mm cb175 carb was the air jet size we probably wouldn't have Victoria! Then Kop kept hounding me about buying parts bikes and i told him OK we are gonna go see Tony right now. We had been asking Tony about one of his "Project bikes" since we picked up Lucky. Then Zeke told Tony seeing the 175 buried like that made him sad. Then I said to Tony, "you know you need to sell it to us." Then he said, "I know!" He has said no to us about that bike since we were in there. Then one of Tony's guys said, "You walked in here at the right time!"
I was perplexed when we first discovered the 20mm on top of the cb200 carbs
Then I checked the fiche and the parts were identical except for a few numbers.
Slides are identical 18mm
Venturi' the same
The only difference I can find so far is the air jet size!
"Then drill a .2mm hole and..."
The first word out of Zeke's mouth when he started removing all the pipes was "Victoria" his momma said he could fix it up and sell it. He said, "she is mine all mine and dad the only think you are doing is helping me break a bolt loose on her!" He wants to keep her stock to ride her to school...and what it would take to get a bonded title for LUCKY in Texas we now have Victoria with a Title because of you Guys!!!! Thank you guys Tony, Teazer, Kop!!!!
Thanks for letting us discover...
PS don't tell Zeke I disassembled one of his carbs to measure it :)
redliner this one?
no joke she is yours! Nobody is going to buy her! I don't joke about motorcycles!
Oh man, my roommies are already tearing the thing to pieces and losing their minds over the excitement of learning to ride. I imagine they're just as excited as Zeke with your projects, hahaha!
Thanks again mate! You just made our year!
Redliner you do beautiful work and work on beautiful bikes! Looking forward to seeing your projects. You are our hero...we would keep our motorcycles in our bedrooms if our women folk would let us :) cheers mate!
Right now you're a hero to my poor bored room mates!
Hey that's ok, if you want to leave your bikes in my room you're welcome :)
Talked with Chris Schumann and he helped us track down what may have caused the seal failure. We used their Viton seals and they were a little bigger in diameter than the stock seals. The inner racing springs we got from Vintage Advantage were difficult to get over the seal and when we disassembled we had a time of wiggling it off the seal. So the inner spring was coming in contact with the seal.
Will the beehive valve springs be a good solution? Or maybe another seal, go back with stock seals? Suggestions?
As always thank you...Zeke has his own build he wants to do all buy himself you can follow it at http://www.dotheton.com/forum/index.php?topic=52299.new#new
