Father Son 75 CB200T Rise From the Ruins
Stock CB200 seals are fine. In fact we fit 200 guides and seals in our sloper motors too.
BTW, slide on a CB200 is 18mm diameter, 30mm tall same as some CB175s. Sloper 175 were 20mm diameter by 33mm tall which is the same as a CB or CL 160 according to my notes - which are not necessarily 110% accurate but they are the only ones I have ;-)
teazer said:
Hold off on the tensioner bolt fix until you have had a chance to work out a new blade type solution because that may require a different adjuster.
Teazer can you expound on what you meant on "blade type"? We got the cbr600 cam chain tensioner in the mail today."
Those are what I meant. Flat (curved) blades rather than rollers. All modern bikes use tensioners and guides like those to restrain the cam chain. Make sure thgat the chain is free to moved between the side rails.
Been doing research on beehive valve springs. The weight savings seems to be monumental on the valve train.
I am having a difficult time understanding this page from my manual.
On the valve spring load is that kg M per mm / ftlbs per inch?
In other words is that really only 23-27 ftlbs per 1.18 inch for the outer spring?
If you were to use beehives would you add the two springs loads together? Looks like if that is the truth I am going to be laughed at when I call PAC on Monday.
Does the XS650 and Cb750 also went down in valve stem size in his kit.
We have access to a lathe to turn down our retainers. Crazypj said that we would need to worry about harmonics at 30 k rpms and that we would be better served putting a 30 degree back cut on our valves.
However if we can save weight on the valve train why not? Beehive springs are 18 bucks ea...
I know y'all are laughing at me saying "they only have a quarter inch of cam lift ;)"
Don't put a foot in it. Force is measured in pounds and Kg - no feet or metres (or meters) and it appears to be measured at the compressed/fitted length of 30mm. The second line appears to be the same data in pounds and inches. So the total compressed load would be around 17Kgm
So this would be the on seat pressure. What would be the full lift pressure for .40" lift? ).270 * 1.5
We took compressed measurements using 10, 25, 35, and 45 lbs for both sets of valve and then tried to graph on a graphing calculator...
We were trying to see if the graph points were linear...
Mr. Bell says we can run 15-20% less seat pressure and 10-20% less at full lift if we change to beehive springs.
Would that be less the racing spring numbers and not the stock spring numbers???
Yes it would. Stock springs were marginal at best when new and tended to sack out at low miles leaving very low pressures which resulted in valve float. We run R&D springs with Titanium caps.
Kibblewhite use different keepers, so their valves springs and caps all have to be used as a set. R&D work with stock valves or replacements with stock keeper grooves.
The following is for stock cb200
cb200 valve springs weigh in at 31 grams
cb200 55mm piston is roughly 168 grams
Stock 24 mm exhaust valve is 24 grams our NOS valves are 25
Stock 28 mm intake valve is 24 grams our NOS valves are 25
Retainer is 8 grams
The keepers are less than 1 gram
Bert Jan said:
whahaha i used a dremel with extension cord and the sanding thingies on the rubber roll aswell. And i used the Hansen website for reference hahaha great minds think alike ;)
we are Dutch!!!
Here are Johnny B's notes from another thread
"Here is an excerpt from my notes on the engines:
STOCK VALVE DIMENSIONS:
Intake Valves Standard measurements (stock): 24grams
Head dia: 27.98mm (28) Total Length 73.3mm Stem dia: 5.48-5.49mm (service limit 5.42mm) Face: 0.7-1.0 (limit 1.8)
Exhaust Valves Standard measurements (stock): 24grams
Head dia: 23.95mm (24) Total Length 73.3mm Stem dia: 5.46-5.47mm (service limit 5.40mm) Face: 0.7-1.0 (limit 1.8)
(both intake and exhaust appear to be 73.3mm in length with a retainer groove of 3.85mm, and a retainer head of 3.26mm)"
I have been reading John Branson's posts on the web and he made an interesting observation in one post. He said he hadn't found one stock valve spring that was within the correct height tolerances published by Honda. For the cb200 that is 1.18"
How would we go about measuring what the minimum and maximum tolerance would be for an installed spring height both minimum and maximum. I am assuming that the tappet screw is there to pick up any discrepancy within the tolerance. But what is the tolerance beyond the puplished 1.18"? Our vintage advantage springs are significantly shorter as an open spring than stock. R & D's spring chart looks fun. I guess that is why they are called Research and Development.
It seems to me when we installed the rocker arms we had quite a bit of play with the vintage advantage springs.
So if the installed spring height is 1.18" or 30mm what would be the maximum tolerance?
We are looking for our long lost family joules...;)
I think he meant that measuring a spring on the bench out of the engine, they were all shorter than Honda's spec's. The way that installed height is adjusted is with shims or machining the spring seat area. If you sink the valves back into the head, the spring height will be higher than stock and if necessary you can slip some shims under the spring seats.
I had a bunch of them machined at different thicknesses for a CB77 racer but haven't needed to on the 160/175/200 heads so far.
Tappet adjusting screw is there to adjust valve running clearances and does nothing for spring height.
Not so sure about your missing family joules but Crown joules are created on top of the piston... :-)
talley ho sir Teazer! :)
teazer said:
Center pin is not pinned or splined. It's a press fit and has to be correctly indexed. Rod length, pin diameter etc I'll have to look up.
so aside from the camshaft modifications an easy rephase ......
~kop
~kop
Exactly.
We have one here that Pete Fisher at Powroll modified for us a few years ago. The only picture I have appears to be analogue, so that gives you some idea how long that project has been stalled :-(
Crank is easy to rebuild and rods are available with new pins. I think they were Honda 90 OHC single but don't quote me on that.
There are a few 180 motors around and few of them work any better than stock. They did lighten wallets by a chunk, so maybe that counts for something. ;-)
IMHO that motor needs thinner rings and better cam chain control but don't tell anyone I said that. It's a trade secret
